MiniDisplayPort to DisplayPort 1.2 Cable M/M 2m/6.56ft
CAC-1163 The Club 3D Mini DisplayPort™ to DisplayPort™ 1.2 cable enables the connection of your Mini DisplayPort™ supported source device to a monitor or other DisplayPort™ supported device. It features a locking DisplayPort connector providing a secure, dependable connection. Simply press the built-in one- touch latch button to unlock the connector. The Cable is Bi-Directional.
MiniDisplayPort 1.4 HBR3 Cable M/M 2m/6.56 Ft.
The Club 3D Mini DisplayPort™ to DisplayPort™ 1.2 4K60Hz UHD Cable enables the connection of your Mini DisplayPort™ supported source device to a DisplayPort™ supported (Ultra) High Definition Television, Monitor or Projector. The Cable is Bi-Directional.
Maximum resolution:
4K UHD 3840x2160p @60Hz and 3D video
Works with AMD, Nvidia and Intel Graphics solutions.
Features are subject to the system configuration and graphics solution
EAN Code: 8719214470098
UPC Code: 841615100187
Item Code: CAC-1163
MULTI STREAM TRANSPORT
POSSIBLE RESOLUTIONS
