Mini DisplayPort to DisplayPort 1.4 HBR3 8K60Hz/4K120Hz Cable M/M 2m/6.56ft.
The Club 3D CAC-1115 Mini DisplayPort™ to DisplayPort™ 1.4 HBR3 cable enables the connection of your Mini DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device. It features a locking DisplayPort™ connector providing a secure, dependable connection. Simply press the built-in one- touch latch button to unlock the connector.
Mini HDMI to HDMI 4K60Hz Cable M/M 1 m/ 3.28 ft
Mini DisplayPort 1.4 HBR3 Cable M/M 2m / 6.56ft 34 AWG
Mini DisplayPort™ to DisplayPort™ 1.4 HBR3 8K60Hz/4K120Hz Cable M/M 2m/6.56ft.
Product Series: Cable
Product Code: CAC-1115
EAN code: 8719214470630
UPC code: 841615100811
• Downwards compatible to older DisplayPort™ standards
• Support resolutions up to 8K60Hz or 4K120Hz
Applications:
• For the host device like laptop, desktop, video converter adaptor, docking station, projector, gaming and display system like TV*, digital signage, VR/AR system.
• Perfect for Host Devices which are featured with the DP1.4 graphic card that supports DP video signal output for gaming, commercial applications**.
Supported resolutions:
• Support Max. resolution/timing up to 4K120Hz or 8K60Hz
• All
• Club 3D CAC-1115 Mini DisplayPort™ to DisplayPort™ 1.4 HBR3 Cable 2m / 6.56ft.
• 1x Mini DisplayPort™ Male
• 1x DisplayPort™ Male
• Box size: 14.5 x 14.5 x 4.5 cm / 5.71 x 5.71 x 1.38"
• Cable Length : 2 m / 6.56 ft.
• Connector dimensions:
 - MiniDisplayPort™ Male 2.6 x 1.2 x 0.8 cm / 1.03 x 0.47 x 0.32"
 - DisplayPort™ Male 4.75 x 2 x 1.3 cm / 1.87 x 0.78 x 0.512"
• Cable Weight: 80 gr/ 2.82 oz
• Box Weight: 45 gr / 1.59 oz
• Total Weight: 125 gr / 4.41 oz
Note:
