USB 3.0 Active Repeater Cable 10 m/ 32 ft Male/Female
CAC-1402 With this Club3D USB 3.0 Active Repeater Cable series (CAC-1401/CAC-1402/CAC-1403) you can go far beyond the standard USB Cable length limitation of 3 meters, without loss of Data Transfer Speed. The USB 3.0 Active Repeater Cables are fully Plug & Play and do not require any driver installation.
Just connect your external USB device like External HDD/NAS/Digital Camera or External USB Graphics to your system and have flexibility of the increased 5/10/15 meters of extra cable length. The CAC-140x Series support data transfer rates up to 5Gbps over the full length of the cable. The CAC-1402 and CAC-1403 are delivered with a power supply to ensure functionality of power hungry USB devices.
| Connector 1: USB 3.0 Male |
| Connector 2: USB 3.0 Female |
| Power adapter: |
| Input 100-240V |
| 50/60Hz 0.35A max |
| Output: 5V 2000mA |
| Specifications |
| USB 3.0 SuperSpeed specification |
| Supports data transfer speeds up to 5 Gbps |
| Extends 10 meters |
| Plug and play functionality |
| External power supply included * |
| Cable: 22AWG+25AWG+28AWG,OD:7.0m |
| No drivers required |
| Microsoft Windows™ and Apple OS X™ compatible |
| * In most cases the power supply is not required with the exception of some USB HDD and high power wifi networking devices |
| What is included? |
| USB 3.0 Active Repeater Cable 10 meters / 32 feet |
| Power Adapter |
| EAN: 8717249401247 |
| UPC: 854365005305 |
