USB 3.1 Type C to HDMI 2.0a HDR Active Adapter
CAC-1584 - The Club 3D CAC-1584 is a USB 3.1 Type C to HDMI™2.0 a signal converter.It features support for HDR Video quality for deep color media content playback. The CAC-1584 requires the USB C output on the source device to have support for DisplayPort™ Alternate Mode. For HDR to function the source system needs to support DisplayPort™ 1.4 standard. The HDMI™ output is fully compliant to HDMI™ specification version 2.0a. It is ThunderboltI™ 3 Compatible.
Resolution Support
The USB 3.1 Type C to HDMI™ 2.0a HDR Active Adapter supports UHD resolutions up to 4096 x 2160p at 60Hz.
ColorFormats
It supports RGB/YCbCr video color formats with a color depth of 16bpc (or 48 bits per pixel) as long as it fits within the DisplayPort™ and HDMI™ link bandwidth. The CAC-1584 also supports pixel encoding conversion from RGB or YCbCr 4:4:4 to YCbCr 4:2:0 and YCbCr 4:2:0 pass-trough function. In addition HDR with deep color up to 12Bpc at 4K 60Hz is supported through the conversion of RGB/YCbCr 4:4:4 over DP link to YCbCr 4:2:0 on the HDMI™ output with a horizontal expansion to CEA timings.
USB C to HDMI 2.0 UHD Cable Active M/M 1.8m/5.9ft
Product Name: USB 3.1 Type C to HDMI™ 2.0a HDR Active Adapter
Product Series: Adapters
Itemcode: CAC-1584
EAN code: 8719214470845
UPC code: 841615101030
• Features reversible USB C connector
• Thunderbolt™ 3 compatible
• Video Stream Handling
- Pass-trough of other 3D Formats
• Audio Stream Handling
• HDCP Support
• HDMI™ transmitter
- Compliant to HDMI™ specifications version 2.0a
- High Dynamic Range (HDR) support both Static- and Dynamic HDR.
- CEC Support - snooping, tunelling
- 4K 30Hz RGB/YCbCr 4:4:4, up to 16Bpc
Note: For HDR to function, the source system needs to support HDR and DisplayPort™ 1.4 Alternate Mode and the screen needs to have support for HDR and/or HDMI™ 2.0a
Windows 10, 8.1
USB 3.1 Type-C Mal
HDMI™ 2.0a Female
• Box size: 182 x 60 x 35 mm.
• Cable: 177 x 38 x 17 mm.
• Weight: 22 gr.
Club 3D USB 3.1 Type C to HDMI™ 2.0a HDR Active Adapter
POSSIBLE RESOLUTIONS
