HDMI 2.0 4K60Hz UHD 360 Degree Rotary cable 2m/6.74ft
CAC-1360 - The Club 3D HDMI™ 2.0 4K60Hz UHD 360° Rotary Cable can be twisted or turned to virtually any position. The Rotator connectors feature a center ball joint design that enables a 360 degree rotation and bending. The CAC-1360 design ensures signal integrity in any position and its flexibility makes it ideal for installations in tight/narrow spaces where standard connectors are hard to fit without having to bend the cable at sharp angles.
It fully supports the HDMI™ 2.0 with Ethernet specification, ensuring that video up to 4K UHD, 4096x2160p at 60Hz is supported, as well as audio and data streams.
Premium High Speed HDMI 2.0 UHD Extension Cable M/F 3m/9.84ft
HDMI 2.0 4K60Hz RedMere cable 15m/49.2ft
Product Name: HDMI™ 2.0 4K60Hz UHD 360° Rotary Cable 2m/6.56ft Male/Male
Product Series: Cables
Itemcode: CAC-1360
EAN code: 8719214471019
UPC code: 841615101207
• Compliant to HDMI™ with Ethernet specification version 2.0
• Features 360 Degree Rotating Connectors
• Supports up to 32 audio channels for the total audio experience
• Supports up to 1536 KHz audio sample frequency for the highest audio fidelity
All
HDMI™ 2.0 Male
HDMI™ 2.0 Male
• Packing size: 145 x 145 x 45 mm
• Packing Weight: 51 gr.
• Product Weight: 111 gr.
• Product size LxBxD: 2000 x 21 x 10 mm
• Product plus Packing weight: 162 gr.
Club 3D HDMI™ 2.0 4K60Hz UHD 360° Rotary Cable 2m/6.56ft.
POSSIBLE RESOLUTIONS
