Mini DisplayPort 1.4 HBR3 Cable M/M 2m/6.56 Ft.
CAC-1164 The Club 3D Mini DisplayPort™ 1.4 HBR3 cable enables the connection of your Mini DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other Mini DisplayPort™ supported device. Mini DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
Mini DisplayPort 1.2 Cable to HDMI 2.0 UHD 4K60Hz Active Adapter M/M 3m/9.84Ft
Mini DisplayPort 1.2 to HDMI 2.0 Active Adapter
Maximum resolution:
- 8K @ 60Hz
- 4K @ 144 Hz
Without compression (DSC) DisplayPort 1.4 can support up to: - 5K @ 60Hz
Connector 2: Mini DisplayPort™ Male
Product Name: Mini DisplayPort™ 1.4 HBR3 8K60Hz Cable Male / Male 2 mtr. / 6.56 Ft.
Product Series: Accessories
Weight: 91 gr
Item Code: CAC-1164
EAN Code: 8719214470647
UPC Code: 841615100828
Operating System Support
All
In the box
