DisplayPort to DVI-D Single-Link Passive Adapter
CAC-1000 The Club 3D is a passive DVI signal converter. The DisplayPort™ to DVI-D Adapter is the easiest solution for connecting your DisplayPort™ enabled Desktop or Laptop to a DVI enabled High Definition Television, monitor or Projector.
The adapter works with AMD, Intel® and Nvidia® graphics solutions and supports a maximum resolution of 1920x1200p @ 60Hz. Simply connect the DisplayPort™ (male) end of the connector to your computer and plug your existing DVI-D cable from the display into the DVI (female) adapter.
Setup requires no software installation. The circuitry built into the adapter seamlessly converts the DisplayPort™ video signal into a DVI digital video signal.
This professional grade adapter-cable is ceritfied by Vesa
Please note that this adapter is for digital signals only and will not fit analog DVI ports
DisplayPort™ 1.4 to HDMI™ 2.0b HDR Active Adapter
Product Name: DisplayPort™ to DVI-D Single Link Passive Adapter
Product Series: Adapter
Weight: 56 gr
Cable length: 250 mm
Item Code: CAC-1000
EAN Code: 8717249408437
UPC Code: 854365005060
• Club 3D DisplayPort™ to DVI-D Single Link Passive Adapter
• Compliant to DisplayPort™ 1.1a Specification
• Supports Dual Mode DisplayPort™ (DP++)
• Supports resolutions up to WUXGA 1920x1200p @ 60Hz
• No external power needed
• Supports AMD, Nvidia® and Intel® HD/ Iris™ graphics solutions
• Vesa Certified
Connector 1:
DisplayPort™ Male
Connector 2:
DVI-D Female
Operating Systems
Microsoft Windows
In the Box
Club3D CAC-1000 DisplayPort™ to DVI-D Single Link Passive Adapter
-HIGH DEFINITION AND MORE
POSSIBLE RESOLUTIONS
