USB 5Gbps Type-C to Type-A M/F Adapter
The Club 3D CAA-1521 USB 5Gbps Type-C to Type-A M/F Adapter enables the connection of your existing USB peripherals, storage devices and docking stations with the common Type-A male connector plug to the latest Laptops, professional tablets and Ultrabooks featuring USB 5Gbps Type-C outputs.
The adapter is backwards compatible and supports previous USB specifications(480Mbps). The USB 5Gbps specification ensures a bitrate of 5Gbps for fast transfer of large files.
USB 3.2 Gen1 Type C to DisplayPort 1.2 4K60Hz
Product Series: Adapter
Product Code: CAA-1521
EAN code: 8719214470425
UPC code: 841615100545
Connect USB Type-A devices to USB 5Gbps Type-C enabled Laptops, Tablets and Ultrabooks.
• Supports USB 5Gbps specification, data transfer speed up to 5Gbps.
• Minimal signal loss
• Backwards compatible to support previous USB specifications(480Mbps).
• Small sized versatile tool
• Supports Windows, Apple OS X and Chrome OS.
Applications:
• Cable Management
• All
• 1x CAA-1521 USB 5Gbps Type-C to Type-A M/F Adapter
• USB Type-C Male
• USB Type-A Female
• Box size: 6 x 7 3.5 cm / 2.36 x 2.76 x 1.38"
• USB Type-C Adapter dimensions: see images on our website, scan the QR-code for quick access or visit: www.club-3d.com
• Device Weight: 6 gr / 0.21 oz
• Box Weight: 34 gr / 1.2 oz
• Total Weight: 45 gr / 1.58 oz
No extra information found.
