USB 3.0 to Dual DVI Graphics Adapter
CSV-2604 The SenseVision USB 3.0 to Dual DVI Graphics Adapter enables a quick and convenient connection between your laptop, (Windows) tablet or Ultrabook and two DVI enabled Monitors, Televisions or Projectors. Featuring the advanced DisplayLink DL-3900 chipset, it functions as an external graphics card and delivers high quality video at resolutions up to 2048x1152p (or 1920x1200p). One output supports DVI-I, enabling the use of a legacy VGA monitor (Club 3D CAA-DMA>CFA required), the other supports DVI-D, enabling the use of an HDMI™ monitor or TV (Club 3D CAA-DMD>HFD3 required).
It’s a cost effective solution for any power user who wants to increase their desktop space and boost their productivity significantly.
USB 3.2 Gen1 Type A to HDMI™ Dual Monitor 4K60Hz
USB Gen1 Type A Dual Display Docking Station
Product Name: USB 3.0 to dual DVI Graphics Adapter
Product Series: SenseVision
Weight: 120 gr
Cable length: 80mm
Item Code: CSV-2604
EAN Code: 8719214470418
UPC Code: 841615100507
USB 3.0 Type A male x1
Micro USB DC-5V input
Power draw
14.43W operating power
1.95W Suspend mode
DVI-I female x1
DVI-D female x1
3.5mm AudioJack
Driver CD
Premium Aluminum design
Supports DVI-I analog monitors (VGA supported w. adapter)
Supports DVI-D digital monitors (HDMI supported w. adapter)
Supports resolutions up to:
For Single Screen Setup: 2048x1152p (or 1920x1200p) @60Hz
For Dual Screen Setup: 2 x 2048x1152p (or 1920x1200p) @60Hz
3.5mm AudioJack
USB Bus powered*
DisplayLink DL-3900 chipset inside
GPU: AMD, Intel or Nvidia
RAM: 1GB or higher
USB port: 3.0
30MB of available disk space
Supported Operating Systems:
