Multi Stream Transport (MST) Hub DisplayPort™ 1.2 Dual Monitor
CSV-5200 - The Club 3D SenseVision MST Hubs utilize Multi Stream Transport, a unique DisplayPort™ 1.2 feature that creates the ability to transport multiple independent uncompressed display (and audio) streams over a single cable, supporting protected content and high performance applications such as 3D gaming.
This enables the use of multiple monitors connected by MST hub configuration. The Club 3D MST Hubs is able to distribute those video streams to the connected screens. The CSV-5200 is Plug & Play and does not require any driver installation.
The Club 3D MST Hubs do not increase the bandwidth of the DisplayPort™ 1.2 output of the source system but enable the optimal use of it.
Note: When using a DisplayPort™ 1.1 video card the MST hub will act as a splitter, automatically mirroring your video source across all displays.
Check out the downloads tab below for more information
USB Gen1 Type A Dual Display Docking Station
USB 3.2 Gen1 Type A 3-Ports Hub with Gigabit Ethernet
Product Name: Club 3D Multi Stream Transport (MST) Hub DisplayPort 1-2
Product Series: SenseVision
Item Code: CSV-5200
EAN Code: 8717249400851
UPC code: 854365005787
DisplayPort 1.2 Male
Micro USB Female for Power
2x DisplayPort Female
• Compliant with: DisplayPort v1.2a, DisplayPort v1.1a, VESA DDM Standard, HDCP V2.0, Display Id,and EDID V1.4
• Supports main link rates of 5.4 Gbps (HBR2), 2.7Gbps (HBR) and 1.62Gbps (RBR) from source
• Input pixel dat a depth 6/8/10/12 bits and supports output pixel format RGB444
• Supports Advanced Wide Eye SerDes technology enables high Jitter performance
• Dual Monitor setup resolution up to 2x 2560X1600p @ 60Hz
• Supports AMD Eyefinity
• Compatible with Microsoft Surface Pro and Intel NUC platforms
• Works with AMD, Nvidia and Intel Graphics solutions
Note: Some Notebooks/Tablets/MiniPC's have Integrated Graphics Chips which do not support more than 3 screens in total. Please consult with your device specifications for further information.
Microsoft Windows 10/ 8.1
• Club 3D Multi Stream Transport (MST) Hub CSV-5200
• Instruction manual
• Mini-Displayport to Displayport Adapter (CAC-1110)
