USB 3.2 Gen 1 Dual Display 4K60Hz Docking Station
CSV-1460 - The SenseVision USB 3.2 Gen 1 Dual Display 4K 60Hz Docking Station is designed to satisfy all your connectivity demands. It provides no less than 6 USB 3.2 Gen 1 Ports, Headphone connection, Microphone connection, Gigabit Ethernet port and 2 x Displayport™ outputs.
It is fully USB C compatible and a USB C cable is included in the box.
With this CSV-1460 you can now connect two Screens at 3840x2160 UHD at 60Hz resolution to almost all existing Notebooks or Tablets just by using a single USB 3.2 Gen 1 port! Featuring the advanced DisplayLink™ DL-6950 chip, you can even connect one screen at a resolution of 5K at 60Hz!
The SenseVision USB 3.2 Gen 1 Dual Display Docking Station has a convenient design and detachable stand, allowing it to be placed on your desk in horizontal- or vertical position. It's a productivity enhancing tool for any power user working in a (semi) professional environment.
Dual Mode DisplayPort™:
The SenseVision USB 3.2 Gen 1 Dual Display 4K 60Hz Docking Station has 2 Displayport™++ outputs or in other words, Displayport™ 1.2 Dual Mode. This means that for the conversion of the video signal to DVI or HDMI™ passive cables or adapters must be used.
Ultra Smart Docking Station
Product Name
Product Series: SenseVision
Itemcode: CSV-1460
EAN code: 8719214470777
UPC code: 841615100965
• Portable Universal USB 3.2 Gen 1 Dual Display 4K 60Hz Docking Station
• Fully USB C compatibel with USB C cable included in the box
• DisplayLink™ DL-6950 chip inside
• Supports dual External monitors via Displayport™
• Max supported resolution up to:
For Single Screen Setup: 5120x2880 @ 60Hz
For Dual Screen Setup: 2 x 3840x2160 @ 60Hz
• USB 3.2 Gen 1 downstream port x 6 (BC 1.2 quick charging x1)
• Supports Gigabit Ethernet (10/ 100/ 1000Mbps)
• Audio: 2 x 3.5 mm Jack for Headphone and Microphone
Microsoft Windows 8.1/10
• USB 3.2 Gen 1 Dual Display 4K 60Hz Docking Station
• Power Adapter 20V/2.25A
• 2* USB 3.2 Gen 1 cable (USB Type-A to B, 1 meter and USB Type C to B 1meter )
• Quick install guide
Inputs:
• USB 3.2 Gen 1 B male x 1
• DC 5v female x 1
Outputs:
• Displayport™ x 2
• USB A 3.2 Gen 1  x 6
• Gigabit Ethernet port x 1
• 3.5mm Audio jack 2.1 ch x 1 • 3.5mm Mic jack x 1
• Box size: 158 x 248 x 93 mm
• Adapter size: 80 (L) x 35(W) x 195(H)mm
• Cable Length: 270 mm
• Dock Weight: 395 gr.
• USB-B to USB-C Cable Weight: 43 gr.
• USB-Cable Weight: 42 gr.
• AC-Cable Weight: 181 gr.
DOCKING STATION
