HDMI to DisplayPort Adapter
CAC-2330 - The Club 3D HDMI™ to DisplayPort™ Adapter is the perfect solution for connecting devices with an HDMI™ output, such as Game-Console or Notebook, to a display with a DisplayPort™ input.
It is equipped with USB-A port to supply power in case there isn’t enough power from HDMI source. The HDMI™ to DisplayPort™ Adapter supports resolutions up to UHD 4096x2160 at 30 Hz and Full HD 1920 x 1080p at 120Hz.
The CAC-2330 Active Adapter offers plug-and-play installation, providing a hassle-free setup with no software or drivers to install.
The DisplayPort™ output is compliant to DisplayPort™ ++ or Dual Mode.
HDMI 1.4 to VGA Adapter
DisplayPort 1.2 Cable HBR2 M/M 3m/9.84ft 30AWG
Product Name: HDMI™ to DisplayPort™ Adapter Male/Female
Itemcode: CAC-2330
EAN code: 8719214470876
UPC code: 841615101061
• Compliant to Displayport™ 1.1 Dual Mode and lower versions
• HDMI™ compliant receiver
– Link rate up to 2.97 Gbps per channel
– Color depth up to 48 bits
– 3D video timings
• HDCP 1.4 repeater with embedded keys
– Video resolution up to 4096x2160 @ 30 Hz; 1920 x 1080 @ 120 Hz
– Audio 7.1 Ch up to 192 kHz sample rate
• Power
- HDMI source can supply enough power in most cases, the USB-A port only needs to be connectedwhen there isn’t enough power.
- USB cable is for optional extra power.
All
HDMI™ Male
DisplayPort™ Female
• Poly Bag: 110 x 180 mm
• Poly Bag Weight: 7 gr
• Product Length: 180 mm
• Product Weight: 36 gr
• Weight product with bag: 43 gr
In the bag:
POSSIBLE RESOLUTIONS
