HDMI 2.0 4K60Hz UHD RedMere Cable M/M 10m/32.81ft 28 AWG
The Club 3D CAC-2313 HDMI™ 2.0 4K60Hz UHD RedMere® Cable M/M 10m/32.81ft 28 AWG enables the connection of your HDMI™ supported Gaming PC or Laptop to an (Ultra) High Definition Monitor or other HDMI™ supported device. It fully supports the HDMI™ 2.0 with Ethernet specification, ensuring that video up to 4K UHD, 4096x2160p at 60Hz is supported, as well as audio and data streams.
RedMere® Technology
The CAC-2313 contains Active Chips with HDMI™ in-cable equalisation technology, with advanced signal processing allowing to support wide band data across relative thin and long cables while maintaining compatibility with the next generation of HDMI™ 2.0 devices.
Premium High Speed HDMI 4K60Hz UHD Cable M/M 1 m / 3.28 ft 30AWG
Product Series: Cables
Product Code: CAC-2313
EAN code: 8719214470937
UPC code: 841615101122
• Compliant to HDMI™ 2.0 with Ethernet specification
• Professional quality braided cable with Metal connector head
• Supports up to 32 audio channels for the total audio experience
• Supports up to 1536 KHz audio sample frequency for the highest audio fidelity
• Contains Active Chips with in-cable equalization techonology
• The CAC-2313 cable is Uni-directional
• All
• CAC-2313 HDMI™ 2.0 4K60Hz UHD RedMere® Cable M/M 10m/32.81ft 28 AWG
• HDMI™ Male
• HDMI™ Male
• Cable length: 10m / 32.81ft
• Box size: 21 x 21 x 7.5 cm/ 8.27 x 8.27 x 2.96"
• Cable Weight: 578 gr / 20.39 oz
• Box Weight : 112 gr. / 3.95 oz
• Total weight : 690 gr. / 24.34 oz
Note: - Please update your TV Firmware to the version which supports these resolutions/refresh rates ! -‑Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates! Please use one of our Extension/Adapter cables to connect to your devices: In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
This Club 3D HDMI™ * cable is also suitable for: Xbox One, Xbox One S, Xbox 360, PlayStation 4, PS3, Nintendo Switch * Please check your TV/monitor user-manual for its required specifications and maximum resolutions.
-HIGH DEFINITION AND MORE
POSSIBLE RESOLUTIONS
