CAC-1211 - The Club 3D CAC-1211 is a DVI to HDMI™ 1.4 Adapter Cable. Because this Adapter Cable is fully Bi-Directional, it can also be used as a HDMI™ to DVI Adapter Cable.
This CAC-1211 Cable is the easiest solution for connecting your HDMI™ Monitor, Projector or Television to the DVI output of your PC / Notebook or to connect your DVI Monitor, Projector or Television to the HDMI™ output of your PC / Notebook / Game Console.
The CAC-1211 uses premium components and gold plated contacts to ensure the highest performance and maximum ease of use resulting in the best user experience with resolutions up to UHD / 3840 x 2160 at 30 Hz.
Product Name: DVI to HDMI™ 1.4 Cable M/F 2m/6.56ft Bidirectional
Product Series: Cables
Itemcode: CAC-1211
EAN code: 8719214471040
UPC code: 841615101238
• Supports resolutions up to UHD / 3840 x 2160 at 30 Hz.
• Fully Bidirectional
• No external power needed
• Plug & Play
All
• CAC-1211, DVI to HDMI™ 1.4 Cable M/F 2m / 6.56ft, Bidirectional
nput:
• DVI Male
• HDMI™ 1.4 Female
• Box size: 145 x 145 x 45 mm.
• WEIGHT PRODUCT(gr) 101
• WEIGHT BOX(gr): 51
• WEIGHT PRODUCT WITH BOX (gr): 156
• Cable length (mm) 2000
• Cable length (ft) 6.56
• Cable height (mm) 14
• Cable width (mm) 39
POSSIBLE RESOLUTIONS
