Mini DisplayPort to DisplayPort 1.2 M/M 2m/6.56ft
CAC-2163 - The Club 3D Mini DisplayPort™ to DisplayPort™ 1.2 cable enables the connection of your Mini DisplayPort™ supported source device to a monitor or other DisplayPort™ supported device.
It features a locking DisplayPort connector providing a secure, dependable connection. Simply press the built-in one- touch latch button to unlock the connector.
The Cable is 30AWG and fully Bi-Directional. The soft UltraFlex jacket protects the cable from bends and deformation damage.
Product Name: Mini DisplayPort™ to DisplayPort™ 1.2 HBR2 Cable M/M 2m/6.56ft 30AWG
Product Series: Cables
Item Code: CAC-2163
EAN Code: 8719214470807
UPC Code: 841615100996
• DisplayPort™ 1.2a compatible - supports version 1.1a
• Bi-directional
• Supports monitor resolutions up to 3840x2160 @ 60Hz and 3D video
• Supports all (U)HD TV resolutions including 1080p FHD and 4K UHD
• Latching connector for a secure, reliable connection
• Supports HBR2; up to 5.4 Gbps per lane throughput - 21.6 Gbps total
All
Mini DisplayPort™ Male
DisplayPort™ Male
Other Info:
• Product Length: 2 meter / 6.56 feet
• Product WxD: 19 x 12 mm
• Product weight: 64 gr
• Packaging size: 21.5 X 15 x 1.8 cm/ 8.46 x 5.9 x 0.71"
• Poly Bag Weight: 6gr.
Club 3D Mini DisplayPort™ to DisplayPort™ 1.2 HBR2 Cable M/M 2m/6.56ft 30AWG
-HIGH DEFINITION AND MORE
POSSIBLE RESOLUTIONS
