Ultra High Speed HDMI 4K120Hz, 8K60Hz  Certified Cable 48Gbps M/M  1 m/3.28 ft
The Club 3D CAC-1371 Ultra High Speed HDMI™2.1 Certified Cable is built to handle the highest quality video- and audio- signals.
- HDMI™2.1 also supports Static- and Dynamic HDR metadata.
All HDMI™2.1 features are fully supported by this Club 3D CAC-1371 Cable. It is the ideal solution for the ultimate future proof HDMI™2.1 experience.
* Please check your TV/monitor user manual for its required specifications and maximum resolutions.
HDMI 2.0 4K60Hz UHD 360 Degree Rotary cable 2m/6.56ft
HDMI 2.0 UHD Active Optical Cable HDR 4K 60Hz M/M 30m/98.42ft
Product Name: Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Certified Cable 48Gbps M/M 1 m/3.28 ft
Product Series: Cable
Itemcode: CAC-1371
EAN code: 8719214471149
UPC code: 841615101337
• Fully Compliant to the Ultra High Speed HDMI™2.1 Certified specification
• Professional quality cable
• Low EMI emission
• Gold plated connectors for maximum conductivity and 30AWG
• Enhanced gaming and media features
• Color space BT.2020 with 10bits,12bits,16bits
• Supports (U)HD resolutions up to 4K120Hz (with DSC 1.2) or 8K60Hz
• Supports Static- and Dynamic- HDR Metadata
• All
• 1x Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Certified Cable 48Gbps M/M
• HDMI™ Male
• HDMI™ Male
• Box size: 14.5 x 14.5 x 4.5 cm / 5.71 x 5.71 x 1.77 inch
• Cable length approx.: 1m /3.28ft
• Connector dimensions: 5 x 2 x 1 cm / 1.97 x 0.79 x 0.39 inch
• Cable Weight: 68gr / 4.16 oz
• Box Weight: 46 gr / 1.62 oz
• LDPE Bag Weight: 9 gr / 0.32 oz
• Total Weight: 118 gr / 4.16 oz
Note:
- Please update your TV Firmware to the version which supports these resolutions/refresh rates!
- Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support these resolutions/refresh rates!
POSSIBLE RESOLUTIONS
