HDMI 2.0 UHD Active Optical Cable HDR 4K 60Hz M/M 50m/164,04ft
CAC-1391 - The Club 3D HDMI™ 2.0 Hybrid Active Optical Cable features both fiber and copper conductors, providing a lighter, more flexible cable construction, which makes it ideal for installation in narrow spaces and over longer distances. The perfect solution for conference rooms, classrooms, digital signage displays, and more.
This CAC-1391 features a built-in booster circuit that is self-powered through the HDMI ports, allowing you to connect your HDMI-enabled devices at a distance of up to 50 meters with no signal loss.
The cable is Halogen Free, and produced according to the International Electrochemical Commission's Restriction Use of Halogen (IEC 61249-2-21) directive.
This cable features unidirectional architecture, which requires that the cable is installed in the correct direction. Please refer to the source and display labels on the HDMI connectors, in order to ensure that the cable is connected properly.
HDMI 2.0 UHD Active Optical Cable HDR 4K 60Hz M/M 30m/98.42ft
Product Name: HDMI™ 2.0 Hybrid Active Optical Cable HDR 4K 60Hz M/M 50m/ 164,04ft
Product Series: Cables
Itemcode: CAC-1391
EAN code: 8719214471088
UPC code: 841615101276
• Compliant to HDMI™ specification version 2.0b (600Mhz Clock Frequency)
• Total Data bandwidth of 18Gbps
• Supports Dolby® True HD, DTS-HD Master Audio up to 32 audio channels
• Halogen Free and without EMI/RFI emission
• Support for HDR/HDCP/EDID/CEC/DDC
• Plug and Play, no driver software required
• Unidirectional - meaning Source and Display only
• This cable is Hybrid which makes it downwards compatible to other HDMI versions
All
HDMI™ 2.0 Male
HDMI™ 2.0 Male
• Box size: 230 x 230 x 100 mm.
• Box Weight: 162 gr.
• Product Weight: 1348 gr.
• Cable + Bag : 1357 gr.
• Product + Box + Bag Weight: 1519 gr.
• Product height: 90 mm.
• Product width: 170 mm.
• Product Length: 50 meter/ 164,04 feet
• HDMI™ 2.0 Hybrid Active Optical Cable HDR 4K 60Hz M/M 50m/164,04ft
