DisplayPort 1.4 HBR3 8K Cable M/M 5m /16.40ft
CAC-1061 - The Club 3D DisplayPort™ 1.4 HBR3 8K cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device.
DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32. It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage.
Product Name: DisplayPort™ 1.4 HBR3 8K Cable Male/Male 5M / 16.40ft.
Product Series: Cables
Itemcode: CAC-1061
EAN code: 8719214471170
UPC code: 841615101368
• Fully DisplayPort™ 1.4 Compliant, HBR3, 32.4Gbps, 28AWG
• Gold plated
• Without DSC1.2 max resolution supported up to: - 5K @ 60Hz
• Vesa Certified
All
• DisplayPort™ 1.4 Male
• Box size: 175 x 175 x 45 mm.
• Box Weight: 64 gr.
• Product Weight: 384 gr.
• Weight Product with retail box: 448 gr.
• Product height: 12mm.
• Product width: 19 mm.
• Product Length: 5meter/ 16.40feet
• Club 3D DisplayPort™ 1.4 HBR3 8K Cable
POSSIBLE RESOLUTIONS
