DisplayPort™ 1.4 HBR3 8K60Hz or 4K144Hz Extension Cable M/F 2m / 6.56 ft 28AWG
The Club 3D CAC-1022 DisplayPort™ 1.4 HBR3 M/F, 2m/6.56ft. Cable enables the extension of your connection to your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device. DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32.
It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one-touch latch button to unlock the connector.
The soft UltraFlex jacket protects the cable from bends and deformation damage. The Cable is 28AWG and fully Bi-Directional.
Product Name: |
DisplayPort™ 1.4 HBR3 8K60Hz or 4K144Hz Extension Cable |
M/F 2m / 6.56 ft 28AWG |
Product Series: Cable |
Product Code: CAC-1022 |
EAN code: 8719214471316 |
UPC code: 841615101504 |
• Fully DisplayPort™ Version 1.4 Compliant, HBR3, 32.4Gbps |
• Downwards compatible to older DisplayPort standards |
• Support resolutions up to 8K60Hz or 4K144Hz |
• The Cable is 28AWG and fully Bi-Directional |
• MicroSoft OS and Apple OSX |
• Club 3D DisplayPort™ 1.4 HBR3 8K60Hz Extension Cable M/F 2m / 6.56 ft 28AWG. |
Available Interfaces |
• DisplayPort™ 1.4 Male |
• DisplayPort™ 1.4 Female |
• Boxsize: 14.5 x 14.5 x 4.5 cm / 5.71 x 5.71 x 1.77" |
• Cable Length: 2m / 6.56 ft |
• Cable Weight: 134 gr / 4.72 oz |
• ESD bag: 5 gr / 0.17 oz |
• Box Weigth: 45 gr /1.5 oz |
• Retail box including cable and ESD, 184 gr / 6.49 oz |
Note: - Please update your TV Firmware to the version which supports these resolutions/refresh rates ! - Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates! |
- CAC-1022_SPECIFICATION-SHEET_EN.pdf
- CAC-1022_SPECIFICATION-SHEET_DE.pdf
- CAC-1022_SPECIFICATION-SHEET_ES.pdf
