Multi Stream Transport (MST) Hub DisplayPort 1.4 Triple Monitor 4K60hz with DSC1.2
CSV-7300 - The Club-3D Multi Stream Transport(MST)Hub DisplayPort™ 1.4 Triple Monitor 4K60Hz with DSC 1.2 is an integrated solution that allow you to enjoy displaying content onto three different monitors / displays simultaneously under MST mode.
The three screens can accommodate displaying different contents in parallel or by simply extending the existing screen, giving a panoramic view of the content which maximizes the user’s visual experience. With its multi-display capabilities, this hub can serve as a convenient and hassle-free portable, alternative solution to the conventional docking station. It’s the perfect solution for host devices which feature DP1.2 /1.4 graphic cards, for gaming and commercial applications.
USB Type-C to DP 1.2 + USB 3.0 + Type-C Charging Mini Dock
USB 3.0 to Dual DVI Graphics Adapter
Product Name: Multi Stream Transport(MST) Hub DisplayPort™ 1.4 Triple Monitor 4K60Hz with DSC 1.2
Product Series: Video Splitters
Itemcode: CSV-7300
EAN code: 8719214471415
UPC code: 841615101597
• Compliant with DisplayPort™1.4 specification 4K60Hz with DSC 1.2
• Compliant with HDCP 2.2 specification
• Supports dual [email protected] bpp without compression
• DSC 1.2 transport and up to 4-slice decompression
• High Dynamic Range (HDR) video
• SST or up to 3 stream MST
Microsoft Windows® 10
Mac OS®
• CSV-7300, 3 port DisplayPort™ 1.4 MST Hub 4K60Hz
• 1x USB Type A cable for powering the Hub 1 m / 3.28 ft
• Quick Install Guide
Available Interfaces:
• 1x DisplayPort™ Male for connecting to Host
• 3x DisplayPort™ Female for connecting to monitors
• 1x DC Power jack(5V / 2A)
• Box size: 14.5 x 14.5 x 4.5 cm
• Box size: 5.7 x 5.7 x 1.77 inch
• Device size: 7.9 x 7.9 x 1.7 cm
• Device size: 3.11 x 3.11 x 0.67 inch
• Cable to Host : 13 cm / 5.12 inch
• Device Weight: 68gr / 2.4oz
• USB Type A power cable length: 100 cm/ 39.37 inch
• USB Type A power cable weight: 24gr / .85oz
• LDPE Bag Weight: 5gr/ .17oz
• Box Weight: 24gr / .85oz
• Total Weight: 121gr / 4.27oz
MULTI STREAM TRANSPORT
