USB Type C 4-in-1 Hub to HDMI™ 4K60Hz USB Type C PD / USB Type A / Audio jack
CSV-1591 - The Club 3D Hub is a 4-in-1 USB Type-C hub with HDMI™, USB Type-A 2.0, 3.5mm audio and USB Type-C PD charging, the design perfectly suits all DP Alt-mode capable devices. With this hub, you can enjoy ultra high definition video of your host on big screen, enjoy fantastic music, transmit USB 2.0 data and connect USB Type-C PD Adapter to charge the host.
This hub can work on all USB Type-C and Thunderbolt™ 3 hosts that supports DP Alt mode. When working on Thunderbolt™ 3 host, this product transmits DP signal.
USB Type C to VGA + USB 3.0 + USB Type C Charging Mini Dock
USB3.2 Gen1 Type-C Universal Triple 4K Charging Dock
Product Name: USB Type C 4-in-1 Hub to HDMI™ 4K60Hz USB Type C PD / USB Type A / Audio jack
Itemcode: CSV-1591
EAN code: 8719214471453
UPC code: 841615101634
• Upstream:
1x USB Type-C Male (Connection to host) Support DP1.2 Alt mode, with bandwidth max 5.4 Gbps per lane, 4 lanes 21.6Gbps
• Downstream:
1x HDMI™ Female
Support HDMI™ max 4K/60Hz 4:4:4 8bit with 18Gbps Bandwidth
Support 6/8/10/12 bit color depth output
Support output pixel format RGB4:4:4/YCbCr4:4:4/YCbCr4:2:2
Support HDCP 2.2 & HDCP1.4
Support HDR
1x USB Type A 2.0, Max 480Mbps bandwidth
• Support BC 1.2 with max 7.5W([email protected]) downstream charging
• 1x 3.5mm combo audio*
Support 48K/44.1KHz sampling rate Audio output
* Note: Audio can be output from HDMI or 3.5mm audio port, below explanation illustrates the priority of audio output when both HDMI and 3.5mm audio ports are connected.
• When source device is connected to this product prior to sink devices, audio outputs from the port that is connected last.
• When sink devices are connected prior to source device connection, audio outputs from 3.5mm audio port
• CSV-1591, 4-in-1 Hub
• Quick Install Guide
Available Interfaces:
• Upstream:
- 1x USB Type C Male
- (Host connection)
• Downstream:
- 1x HDMI™ 4K60Hz Female for connecting to Monitor
- 1x USB type A, BC1.2 charging
- 1x USB Type-C Female, PD Charging only
- 1x.3.5mm combo audio
• Box size: 10 x 10 x 3 cm
• Box size: 3.93 x 3.93 x 1.18 inch
• Device size: 7.2 x 3.2 x 0.9 cm
• Device size: 2.83 x 1.26 x 0.9 x 0.35 inch
• Device Weight: 35 gr / 1.23 oz
• Box Weight: 65 gr / 2.3 oz
• Total Weight: 105 gr / 3.7 oz
