DVI-D Dual Link 24+1 M/M Cable 3m/9.84ft Bidirectional 28AWG
The Club 3D CAC-1223 is a DVI-D(24+1) Male to DVI-D(24+1) Male Cable. This cable is fully Bidirectional. This CAC-1223 Cable is the easiest solution for connecting your DVI-D Monitor, Projector or Television to the DVI-D output of your PC / Notebook / Game Console.
The CAC-1223 uses premium components and gold plated contacts
to ensure the highest performance and maximum ease of use result- ing in the best user experience with resolutions up to 2560 × 1600 (WQXGA)@ 60 Hz or 1920 x 1080 @ 120Hz, provided your graphic card and your monitor supports these resolutions.
Please use one of our DVI-D (Extension/Adapter) cables to connect to your devices: In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you
DVI-A to VGA Cable M/M 3m/9.9 ft 28AWG
DVI-D Dual Link (24+1) Cable Bidirectional M/M 10m/32.8ft  28AWG
Product Series: Cables
Itemcode: CAC-1223
EAN code: 8719214471507
UPC code: 841615101696
• Supports resolutions up to 2560 × 1600 (WQXGA)@ 60 Hz or 1920 x 1080 @ 120Hz
• Fully Bidirectional
• No external power needed
• Plug & Play
All
• CAC-1223 Cable
• DVI-D (Male)
• DVI-D (Male))
• Boxsize:21x21x3cm
• Boxsize: 8.3x8.3x1.2inch
• CableLength: 3m/9.9ft
• Connector dimensions : 5.3 x 4 x 1.5 cm
• Connector dimensions : 2.1 x 1.6 x 0.6 inch
• Cable Weight: 250 gr / 8.8 oz
• Box Weight 75 gr / 2.65 oz
• Total Weight 325 gr / 11.47 oz
-HIGH DEFINITION AND MORE
