DVI-A to VGA Cable M/M 3m/9.9 ft 28AWG
The Club 3D CAC-1243 is a DVI-A Male to VGA Male Cable. This cable is Unidirectional. This CAC-1243 Cable is the easiest solution for connecting your VGA Monitor, Projector or Television to the DVI-A output of your PC / Notebook / Game Console.
The CAC-1243 uses premium components and gold plated contacts to ensure the highest performance and maximum ease of use resulting in the best user experience with resolutions up to 1600 x 1200@ 60 Hz provided your graphic card and your monitor supports these resolutions.
Please use one of our VGA / DVI (Extension/Adapter) cables to connect to your devices: In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
DVI-D Dual Link 24+1 M/M Cable 3m/9.84ft Bidirectional 28AWG
DVI-D Dual Link (24+1) Cable Bidirectional M/M 10m/32.8ft  28AWG
HDMI 1.4 to DVI Cable M/F 2m/6.56ft Bidirectional
Product Name: CAC-1243 – DVI-A to VGA M/M Cable 3m/9.9Ft 28AWG
Product Series: Adapter
Itemcode: CAC-1243
EAN code: 8719214471514
UPC code: 841615101702
• Compliant to DVI-A specification
• Compliant to VGA specification
• Supports VGA resolutions up to 1600 x 1200 @ 60 Hz
• Unidirectional
• No external power need
• Plug & Play
All
• CAC-1223 Cable
• DVI-A (Male)
• VGA (Male)
• Box size: 21 x 21 x 3.5 cm
• Box size: 8.3 x 8.3 x 1.4 inch
• Cable Length : 3 m / 9.9 ft
• DVI-A Connector dimensions : 5.3 x 4 x 1.5 cm
• DVI-A Connector dimensions : 2.1 x 1.6 x 0.6 inch
• VGA Connector dimensions : 5.3 x 3.4 x 1.7 cm
• VGA Connector dimensions : 2.1 x 1.4 x 0.7 inch
• Cable Weight: 300 gr / 10.6 oz
• Box Weight: 50 gr / 1.9 oz
• Total Weight: 350 gr / 12.5 oz
-HIGH DEFINITION AND MORE
