DisplayPort™ to VGA Black Active Adapter M/F
The Club 3D CAC-2013 is an active DisplayPort™ to VGA signal converter. It enables you to connect your analog VGA Televisions, Monitors or Projectors to your Desktop or Laptop with DisplayPort™ output. The adapter offers hassle free plug and play functionality, so no Driver installation needed and it is powered by the DisplayPort™ output.
The DisplayPort™ interface in the adapter consists of two main lanes for DP data, AUX channel, HPD signal and power. The VGA output is compliant to VSIS standard and supports up to WUXGA RB timings. Supports resolutions up to WUXGA 1920x1200p @ 60Hz.The adapter works with AMD, Nvidia and Intel Graphic Solutions.
In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
DisplayPort™ 1.4 HBR3 Cable VESA Certified  M/M 2 m / 6.56ft 28AWG
DisplayPort™ 1.4 HBR3 8K60Hz or 4K144Hz Extension Cable M/F 2m / 6.56 ft 28AWG
DVI-A to VGA Cable M/M 3m/9.9 ft 28AWG
Product Name: DisplayPortTM to VGA Black Active Adapter M/F
Product Series: Adapters
Itemcode: CAC-2013
EAN code: 8719214471576
UPC code: 841615101764
• Automatic sink detection
• Microsoft Windows 10, 8.1
• Apple OS X
• Club 3D CAC-2013 DisplayPortTM to VGA Active Adapter M/F
•DisplayPort™ Male
•VGA Female
• Total Cable Length: 22.86 cm / 9inch
• Connector dimensions:
- DP Male: 3.7 x 2 x 1 cm /1.45 x 0.79 x 0.39 inch
- VGA Female: 4.18 x 3.8 x 1.57cm / 1.65 x 1.5 x 0.62inch
• Packaging size: 21.5 X 15 x 1.8 cm/ 8.46 x 5.9 x 0.71"
• Poly Bag Weight: 9 gr / 0.32 oz
• Product Weight: 26 gr / 0.91 oz
• Total Weight: 35 gr / 1.23 oz
