High Speed HDMI™ Extension Cable 4K60Hz M/F 5m/16.4ft 26 AWG
The Club 3D CAC-1325 High Speed HDMI™ Extension Cable, 4K60Hz UHD enables you to extend your existing HDMI™ cable length by 5 meters / 16.4 Feet. Nowadays we have many devices that we want to connect to our TV which makes this product a great solution because it creates flexibility for the placing of such devices.
This High Speed HDMI™ 4K60Hz UHD Extension Cable is fully compliant to HDMI™ 1.3 / 1.4 and 2.0 standard to ensure smooth transfer of your Video and Audio signals over the full length of this Extension Cable.
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Certified Cable 48Gbps M/M  1 m/3.28 ft
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Cable 48Gbps M/M  3 m/ 9.84ft
Product Name: High Speed HDMI™ Extension Cable 4K60Hz M/F 5m/16.4ft 26 AWG
Product Series: Cable
Product Code: CAC-1325
EAN code: 8719214471606
UPC code: 841615101795
• High Quality High speed HDMI™ Extension cable, 26 AWG.
• Compliant with HDMI™ 1.3 / 1.4 / 2.0 standard
• Data transfer rate up to 18 Gbps.
• Support resolutions up to [email protected] HDR / [email protected] 3D. *
• Product is fully plug & play and does not require external power.
* Functionality is also dependent on the HDMI™ M/M cable used. In combination with this CAC-1325 extension cable we advise to use HDMI Male/Male cable of 28AWG Quality, like the Club 3D CAC-1371/CAC-1372 and/or CAC-1373
All
CAC-1325 High Speed HDMI™ 4K60Hz UHD Extension Cable M/F 5m/16.4ft
Input: 1x HDMI™ (Male)
Output: 1x HDMI™(Female)
• Box size: 17.5 x 17.5 x 4.5 cm / 6,89 x 6,89 x 1.77 inch
• Cable Length: 5 m / 16.4 ft
• Connector Dimensions:
- HDMI™ Male: 4 x 2 x 1.4 cm / 1.58 x 0.79 x 0.55 inch
- HDMI™ Female: 4 x 2 x 1.2 cm / 1.58 x 0.79 x 0.47 inch
• Cable Weight: 400gr / 14.11 oz
• Box Weight: 63 gr / 2.22oz
• Total Weight: 463 gr / 16.33oz
* Please update your TV Firmware to the version which supports these resolutions/refresh rates !
** Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates!
In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected]
and it will be our pleasure to assist you.
