HDMI AOC Cable 4K120Hz 8K60Hz M/M 20m/65.6 ft
The Club 3D CAC-1379 HDMI™ Active Optical Cable, allows you to connect your favourite Display over a distance of 20 m / 65.62 ft. Nowadays we have many devices that we want to connect to our TV or projector which makes this product a great solution because it creates flexibility for the placing of such devices.
This Ultra High Speed HDMI™ 4K120Hz UHD 8K60Hz Cable is fully compliant to HDMI™ 2.1 standard to ensure smooth transfer of your Video and Audio signals over the full length of this Extension Cable.
Product Name: HDMI™ AOC Cable 4K120Hz 8K60Hz M/M 20m/65.6 ft |
Product Series: Cable |
Product Code: CAC-1379 |
EAN code: 8719214471620 |
UPC code: 841615101818 |
• High Quality Ultra High speed HDMI™ cable |
• Compliant with HDMI™ 2.1 standard |
• Data transfer rate up to 48 Gbps. |
• Support resolutions up to [email protected] / [email protected] 3D. |
• Product is fully plug & play and does not require external power. |
In order to achieve these resolutions / refresh rates, Please update your: |
- TV Firmware to the version which supports these resolutions/refresh rates! |
- Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support these resolutions/refresh rates! |
OS Support: All |
CAC-1379 HDMI™ AOC Cable 4K120Hz M/M 20m / 65.6 ft |
Available Interfaces |
Input: 1x HDMI™ (Male) |
Output: 1x HDMI™ (Male) |
• Box size: 23 x 23 x 5 cm / 9 x 9 x 1.97 inch |
• Cable Length: 20 m / 65.6 ft |
• Connector Dimensions: HDMI™ Male: 6.7 x 2 x 0.9 cm / 2.64 x 0.79 x 0.36 inch |
• Cable Weight: 552 gr / 19.47 oz |
• Box Weight: 110 gr / 3.88 oz |
• Total Weight: 662 gr / 23.35 oz |
In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you. |
This Club 3D HDMI™ * cable is also suitable for: Xbox Series X, Xbox Series S, PlayStation 5, Nvidia RTX 3000 series, AMD Radeon RX 6800 series. |
* Please check your TV/monitor user-manual for its required specifications and maximum resolutions. |
- CAC-1379 SPECIFICATION-SHEET_EN.pdf
- CAC-1379 SPECIFICATION-SHEET_DE.pdf
- CAC-1379 SPECIFICATION-SHEET_ES.pdf
- CAC-1379 SPECIFICATION-SHEET_JP.pdf
