USB 3.2 Gen1 Active Repeater Cable 5m/ 16.4 ft M/F 28AWG
With this Club3D USB 3.2 Gen1 Active Repeater Cable CAC-1404, you can go far beyond the standard USB Cable length limitation of 3 meters /9.84 feet, without loss of Data Transfer Speed. The USB 3.2 Gen1 Active Repeater Cables are fully Plug & Play and do not require any driver installation. Just connect your external USB device like External HDD/NAS/Digital Camera or External USB Graphics to your system with the CAC-1404 and have flexibility of the increased 5 meters /16.4 feet of extra cable length. Also for a VR experience at the sofa away from the notebook or PC this cable provides you with the freedom of movement.
The CAC-1404 supports data transfer rates up to 5Gbps over the full length of the cable.
As an option, for powering the repeater, we offer our CAC-1408, an USB Type A to Micro USB M/M cable of 1 meter, please order seperatly.
We recommend an external powersource which can provide 5V @ 2.4A (12W) for example our CAC-1912.
OS Support: Windows™ and Mac OSX™ compatible
USB 3.2 Gen1 Active Repeater Cable 10m / 32.8ft M/F 28AWG
USB 3.2 Gen1 Active Repeater Cable 15m/ 49.2 ft M/F 28AWG
Product Name: USB 3.2 Gen1 Active Repeater Cable 5m/ 16.4 ft M/F 28AWG
Product Series: Cable
Product Code: CAC-1404
EAN code: 8719214471774
UPC code: 841615102006
• USB 3.2 Gen1 SuperSpeed specification
• Supports data transfer speeds up to 5 Gbps
• Plug and play functionality
• No drivers required
• Cable: 28AWG, OD: 5.5mm
• Windows™ and Mac OSX™ compatible
• 1x CAC-1404 Active Repeater Cable 5 m/ 16.4 ft Male/Female
•1x USB 3.2 Gen1 Male
•USB 3.2 Gen1 Female
• Box size 17.5 x 17.5 x 4.5cm / 6.89 x 6.89 x 1.77"
• Cable Weight: 251 gr/ 8.85 oz
• Total Cable length 5m / 16.4 ft
• Connector dimensions:
 USB Type A Male 4 x 0.7 x 1.5 cm / 1.57 x 0.28 x 0.6“
 USB Type A Female 7.5 x 1.3 x 2.2 cm / 2.96 x 0.51 x 0.87“
• Box Weight 56 gr / 1.98 oz
• Total Weight: 307 gr/ 10.83 oz
