USB 3.2 Gen1 Active Repeater Cable 15m/ 49.2 ft M/F 28AWG
With this Club3D USB 3.2 Gen1 Active Repeater Cable CAC-1406, you can go far beyond the standard USB Cable length limitation of 3 meters /9.84 feet, without loss of Data Transfer Speed. The USB 3.2 Gen1 Active Repeater Cables are fully Plug & Play and do not require any driver installation. Just connect your external USB device like External HDD/NAS/Digital Camera or External USB Graphics to your system with the CAC-1406 and have flexibility of the increased 15 meters / 49.2 feet of extra cable length. Also for a VR experience at the sofa away from the notebook or PC this cable provides you with the freedom of movement.
The CAC-1406 supports data transfer rates up to 5Gbps over the full length of the cable.
For powering the repeater, we included our CAC-1408, an USB Type A to Micro USB M/M cable of 1m/3.28ft.
You have the flexibility to power the CAC-1406 on each of the repeaters or at the end with the provided CAC-1408.
We recommend an external powersource which can provide 5V @ 2.4A (12W) for example our CAC-1912.
USB 3.2 Gen1 Active Repeater Cable 5m/ 16.4 ft M/F 28AWG
USB 3.2 Gen1 Active Repeater Cable 10m / 32.8ft M/F 28AWG
Product Series: Cable
Product Code: CAC-1406
EAN code: 8719214471798
UPC code: 841615102020
• USB 3.2 Gen1 SuperSpeed specification
• Supports data transfer speeds up to 5 Gbps
• Plug and play functionality
• No drivers required
• Cable: 28AWG, OD: 5.5mm
• Windows™ and Mac OSX™ compatible
• 1x CAC-1406 Active Repeater Cable M/F 15 m/ 49.2 ft
• 1x CAC-1408 USB Type A to Micro USB cable M/M 1m/ 3.28 ft
• 1x USB 3.2 Gen1 Male
• 3.2 Gen1 Female
• Box size 21 x 21 x 7.5 cm / 8.27 x 8.27 x 2.96”
• Cable Weight: 949 gr/ 33.48 oz
• Total Cable length 15m / 49.2 ft
• Connector dimensions:
 USB Type A Male 4 x 0.7 x 1.5 cm / 1.57 x 0.28 x 0.6“
 USB Type A Female 7.5 x 1.3 x 2.2 cm / 2.96 x 0.51 x 0.87“
• 1x CAC-1408 USB Type A to Micro USB cable M/M 1m/ 3.28 ft - 31 gr/ 1.09 oz
• Box Weight 95 gr / 3.35 oz
• Total Weight: 1075 gr/ 37.92 oz
