USB 2.0 Type-A to Micro USB Cable M/M 1m /3.28ft
CAC-1408 - The Club 3D USB 2.0 Type-A to Micro USB Cable enables the connection of your existing USB Type A output connections, Laptops, tablets and Ultrabooks, Power Chargers, etc. to Micro USB inputs, like camera's, Phones and our range of extension cables and adapters.
The cable is compatible and supports USB 2.0 .
The USB 2.0 specification ensures a bitrate of 480Mbps for transfer of files.
USB 3.2 Gen1 Active Repeater Cable 5m/ 16.4 ft M/F 28AWG
USB 3.2 Gen1 Active Repeater Cable 10m / 32.8ft M/F 28AWG
USB 3.2 Gen1 Active Repeater Cable 15m/ 49.2 ft M/F 28AWG
Product Series: Cables
Product Code: CAC-1408
EAN code: 8719214471880
UPC code: 841615102099
• Connect USB type A to Micro USB enabled devices
• USB 2.0 data transfer rates up to 480Mbps when used with USB 2.0 host and device
• Compatible to support USB 2.0 specification.
• This cable is Bi-directional
• Supports both data and power
• Maximum Power output 0.5W
• All
• 1x USB 2.0 Type-A to Micro USB Cable
• USB Type A Male
• Micro USB Male
• Packaging size: 11 X 18 x 0.6cm/ 4.3 x 7.1 x 0.24"
• Bag Weigth: 5 gr/ 0.14 oz
• Cable Length: 1m / 3.28 ft
• Cable Weight: 26 gr/ 0.95 oz
• Total Weight: 31 gr/ 1.09 oz
