USB Gen2 Type C to HDMI 4K120Hz HDR10 with DSC 1.2 Active Adapter M/F
The Club 3D CAC-1586 is the perfect solution to connect to any HDMI™ 8K30Hz* or 4K120Hz ready display. In case you have a DisplayPort™ Alt Mode 1.4 ready PC with a USB Gen2 Type C connection or any other device that lacks the new HDMI™ 8K30Hz or 4K120Hz specification, the Club3D CAC-1586 will be the simple way to upgrade your device and connect to your new TV*. With its DP1.4 Alt Mode DSC video compression technology, this adapter is able to convert DP1.4 Alt Mode video signals to HDMI™, supporting video display resolutions up to 8K (7680 x 4320)@60Hz ** or 4K (3840 x 2160)@120Hz ** and creating life like colors and movements with HDR10 giving users the ultimate visual experience. The Adapter is powered thru the USB Gen2 Type Connection.
Ultra High Speed HDMI 4K120Hz, 8K60Hz  Certified Cable 48Gbps M/M  1.5 m/4.92 ft
USB Gen2 Type C to HDMI™ 4K120Hz HDR10 with DSC 1.2 Active Adapter M/F
Product Series:Adapter
Product Code: CAC-1586
EAN code: 8719214471842
UPC code: 841615102075
• Compliant with VESA DisplayPort™ v1.4 Specification
• Compliant with HDMI™ Specification
• Support HDCP 2.2
• Support Max. resolution/refresh rates up to 4k@120Hz
• Support Dynamic HDR10
• No External Power needed(Powered thru the USB Type C connection)
Applications:
• For the host device like laptop, desktop, projector, gaming and display system like TV*, digital signage, VR/AR system.
• Perfect for Host Devices which are featured with the DP1.4 Alt Mode graphic card that supports DP video signal thru an USB Gen2 Type Coutput for gaming, commercial applications**
Supported resolutions:
• Support Max. resolution/timing up to 4k@120Hz
• All
• CAC-1586 Active Adapter
• USB Gen2 Type C Male
• 1x HDMI™ Female
Note: Cable should meet 8K60Hz specs(or above) and should not exceed 2 m / 6.56 ft
• Box size: 7 x 32 x 3.5cm / 2.76 x 12.6 x 1.38 "
• Device size: 3.15 x 6 x 1.4cm / 1.24 x 2.36 x 0.55"
• Cable length approx.: 15 cm / 5.9"
• Total length approx.: 21 cm / 8.27"
• Connector dimensions:
- USB Type C Male 2.9 x 1.2 x 0.7 cm / 1.15 x 0.5 x 0.28"
• Device Weight: 36 gr / 1.27oz
• Box Weight: 34gr / 1.2 oz
• Total Weight: 75 gr /2.64 oz
This product is SPECIFICALLY designed to work with the latest Graphics Processing Units (GPU’s) which supports DSC 1.2:
At the time of printing these are the supported GPUs.
NVIDIA TURING™ RTX: TITAN RTX, RTX 2080, RTX 2070, RTX 2060
Intel 11th Gen GPUs, Intel 10th Gen GPUs
Please make absolutely sure that you’re using one the above mentioned graphical technologies in order to obtain the Superior functionality of our Club 3D CAC-1586.
This adapter will function with lower specifications GPU’s, be aware performance will be reduced due to the specifications of that GPU !!
Functionality is also dependent on the HDMI™ M/M cable used. In combination with this CAC-1586 adapter we advise
to use HDMI™ Male/Male cable of 28AWG Quality or above, like the Club 3D CAC-1370, CAC-1371 and/or CAC-1372 up
to 2m/ 6.56 ft max. !
Note:
- * Please update your TV Firmware to the version which supports these resolutions/refresh rates !
- ** Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates!
