USB Gen1 Type-C to Type-A Active Adapter Cable 5Gbps M/F 10m/32.8ft
The Club 3D CAC-1538 USB Gen1 Type-C to Type-A Active Adapter Cable 5Gbps M/F 10m/32.8ft connects your Notebook, Tablet or Phone with USB Type-C output to your favorite existing Peripherals, Accessories and Chargers featuring the common USB Type-A plug. It enables Data and Power over a single cable. This cable supports USB 3.2 Gen1. SuperSpeed+ data up to 5Gbps and up to 900mA output for Downstream charging or powering your USB Type-A enabled Notebook, Tablet or Smartphone.
USB Gen2 Type-C to Type-A Cable 10Gbps M/F 5m/16.4ft
USB 3.1 Gen2 Type-C to Type-B Cable M/M 1m/3.28ft
USB 2.0 Type-A to Micro USB Cable M/M 1m /3.28ft
Product Series: Cables
Product Code: CAC-1538
EAN code: 8719214472139
UPC code: 841615102365
• USB Gen1 SuperSpeed+ Data up to 5Gbps
• USB Gen1 Data and Charging through a single cable
• USB Power, max. 900mA Downstream charging to USB Type-A device
• Works with all USB Type-C enabled devices
• Output connector USB Type-A Female
• Unidirectional
• All
• CAC-1538 USB Gen1 Type-C to Type-A Active Adapter Cable 5Gbps M/F 10m/32.8ft
• USB Type-C Male
• 1x USB Type-A Female
• Box size: 23 x 23 x 5 cm / 9 x 9 x 1.97"
• Total Cable length approx.: 10m / 32.8 ft
• USB Type-C Male Connector dimensions: 4.6 x 1.24 x 0.63 cm / 1.81 x 0.48 x 0.24"
• USB Type-A Female Connector dimensions: 5 x 2.25 x 1.15 cm / 1.97 x 0.88 x 0.45"
• Cable Weight: 497 gr / 17.53 oz
• Box Weight: 93 gr / 3.28 oz
• Total Weight: 590 gr / 20.81 oz
