VGA Cable Bidirectional M/M 3m/9.84ft 28AWG
The Club 3D CAC-1703 VGA Cable Bidirectional M/M 3m/9.84ft 28AWG links any VGA-equipped desktop, laptop or adapter to a monitor, display, beamer or projector with a 15-pin VGA Female port. Ideal for at home or work, the cable creates a reliable connection for anything from gaming to video projection and supports up to Full HD 1080p (max. resolution of  1920 x 1080).
This quality VGA cable provides superior performance thanks to the combined effect of its Gold plated connectors and 28 AWG conductors. Internal shielding provides reduced crosstalk, suppresses noise, and helps prevent electromagnetic interference (EMI) and radio frequency interference (RFI).
Experience a reliable, high-quality connection with this convenient VGA to VGA 3m / 9.84ft cable.
USB Gen1 Type-C Triple Display Dynamic PD Charging Dock with 65 Watt PS
USB Gen1 Type-C 9-in-1 hub with HDMI, VGA, 2x USB Gen1 Type-A, RJ45, SD/Micro SD card slots and USB Gen1 Type-C Female port
Product Series: Cable
Product Code: CAC-1703
EAN code: 8719214472184
UPC code: 841615102426
• Standard 15-pin VGA Male to VGA Male cable
• Inner conductor: 3 x coax (RGB)
• Gold-plated connectors
• Shielded for EMI/RFI interference
• Resolution up to 1920 x 1080 (Full HD 1080p)
Supported resolutions:
• All
• CAC-1703
• VGA Male
• VGA Male
• Box size: 17.5 x 17.5 x 4.5 cm / 6.89 x 6.89 x 1.77"
• Cable length: 3m / 9.84ft
• Connector dimensions: 4.4 x 3.3 x 1.6 cm / 1.73 x 1.3 x 0.63"
• Cable Weight: 225 gr / 7.94 oz
• Box Weight: 63 gr / 2.22 oz
• Total Weight: 288 gr / 10.16 oz
