VGA and USB Type-A to HDMI Adapter with Pigtail M/F 0.6m/1.97ft 28AWG
The Club 3D CAC-1720 VGA and USB Type-A to HDMI™ Adapter with Pigtail M/F 0.6m/1.97ft 28AWG links any VGA-equipped desktop, laptop or adapter to a monitor, display, beamer or projector with a HDMI™ Male port. Ideal for at home or work, the adapter creates a reliable connection for anything from gaming to video projection and supports up to Full HD 1080p(max. resolution of  1920 x 1080). An USB Type-A port is also provide for External Power. This quality VGA to HDMI™ cable provides superior performance thanks to the combined effect of its Gold plated connectors and 28 AWG conductors. Internal shielding provides reduced crosstalk, suppresses noise, and helps prevent electromagnetic interference (EMI) and radio frequency interference (RFI).
Experience a reliable, high-quality connection with this convenient VGA and USB Type-A to HDMI™ Adapter.
USB Gen1 Type-C 9-in-1 hub with HDMI, VGA, 2x USB Gen1 Type-A, RJ45, SD/Micro SD card slots and USB Gen1 Type-C Female port
USB Gen1 Type-C Triple Display Dynamic PD Charging Dock with 65 Watt PS
Product Series: Adapter
Product Code: CAC-1720
EAN code: 8719214472214
UPC code: 841615102471
• Standard 15-pin VGA Male to HDMI™ Female adapter
• USB Type-A connector for external power
• Gold-plated connectors
• Shielded for EMI/RFI interference
• Resolution up to 1920 x 1080 (Full HD 1080p)
• All
• CAC-1720
• VGA Male
• USB Type-A Male (for External Power)
• HDMI™ Female
• Box size: 17.5 x 17.5 x 4.5 cm / 6.89 x 6.89 x 1.77"
• Cable length: 0.6m/1.97ft
• HDMI™ Pigtail dimensions: 8 x 5.6 x 1.2 cm / 3.15 x 2.2 x 0.47"
• VGA Connector dimensions: 4.8 x 3.4 x 1.5 cm / 1.89 x 1.34 x 0.59"
• USB Connector dimensions: 3.5 x 1.6 x 0.79 cm/ 1.38 x 0.63 x 0.31"
• Cable Weight: 110 gr / 3.88 oz
• Box Weight: 63 gr / 2.22 oz
• Total Weight: 173 gr / 6.1 oz
