The Club 3D CAC-1515 USB2.0 Type-C Bi-Directional USB-IF Certified Cable, Data 480Mb, PD 240W(48V/5A) EPR, Extended Power Range M/M 4 m / 13.13 ft connects your Notebook, Tablet or Phone with USB Type-C output to your favorite existing Peripherals, Accessories and Chargers. It enables Data and Power over a single cable and both ways. This cable supports USB2.0 data up to 480Mbps and up to 240Watt(48V/5A) output for Downstream charging or powering your Notebook, Tablet or Smartphone.
USB2 Type-C Bi-Directional USB-IF Certified Cable Data 480Mb, PD 240W(48V/5A) EPR M/M 1m / 3.23 ft
USB2 Type-C Bi-Directional USB-IF Certified Cable, Data 480Mb, PD 240W(48V/5A) EPR M/M 2m/6.56ft
USB2 Type-C Bi-Directional USB-IF Certified Cable Data 480Mb, PD 240W(48V/5A) EPR M/M 4 m / 13.13 ft
Product Series: Cables
Product Code: CAC-1515
EAN code: 8719214472641
UPC code: 841615102884
USB-IF Certified TID: 8511
• USB Power Delivery, 240 Watt(48V/5A) charging
• Fully Bidirectional
• E-marker IC
• 240W EPR(Extended Power Range)Charging through a single cable
• USB2.0 Data Speed up to 480Mbps
• USB-IF Certified
• CAC-1515 USB2 Type-C Bi-Directional USB-IF Certified Cable Data 480Mb, PD 240W(48V/5A) EPR M/M 4 m / 13.13 ft
• USB Type-C Male
• USB Type-C Male
• Box size: 14.5 x 14.5 x 4.5 cm / 5.71 x 5.71 x 1.77"
• Total Cable length approx.: 4 m / 13.13 ft
• USB Type-C Male Connector dimensions: 3.62 x 1.2 x 0.63 cm / 1.43 x 0.47 x 0.25"
• Cable Weight: 211 gr / 7.44 oz
• Box Weight: 45 gr / 1.59 oz
• Total Weight: 256 gr / 9.03 oz
Some external devices, like the computer mouse, also need some power from the USB Port to operate. This power can be delivered through standard USB connection. The Default Power that USB 1.0 and 2.0 can deliver is 2.5Watt (5Volt, 0.5A), USB 3.0 and 3.1 can deliver 4.5Watt (5V, 0.9A), USB 3.2 can deliver 7.5W (5V/1.5A) and USB 4 can deliver 240Watt. For the external devices requiring more power, different technologies have been developed. It is important to distinguish following 2 technologies: "USB Power Delivery" and "USB Battery Charging".
