USB Type-C® 4-port 10G Data hub with PD3.0 Charging
The Club 3D CSV-1548 USB Type-C® 4-port 10G Data hub with PD3.0 Charging, the compact and comprehensive super fast data hub allows you virtually to connect all data transfer peripherals, including phones/tablets. The hub is compatible with both new Gen2 USB peripherals as well as downwards compatible to legacy USB devices, max data tranfer rate up to 10Gbps(1280MB/s). Extended connection for existing devices, such as a hard drive, SSD, USB flash,mouse, keyboard and/or printer. The Hub also supports Power Delivery 3.0 charging on 1 port.
Product Name: USB Type-C® 4-port 10G Data hub with PD3.0 Charging |
Produktserie: Adapter |
Artikelcode: CSV-1548 |
EAN code: 8719214472962 |
UPC code: 841615103249 |
• 1x USB Type-C® port(with RED lining) supports 10Gbps data transfer and PD3.0 charging max. 100 Watt(20V/5A) |
• 3x USB Type-C® supports: |
USB3.1 Gen2 10 Gbps data transmissions |
Support max. 5V/1.5A(7.5Watt) downstream charging, total for these 3 ports 5V/2.4A(12Watt) |
• Support PD3.0 Fast Role Swap(FRS) |
• Support Plug & Play |
• Does NOT support Video |
• Compact & Slim design |
Applications: |
• Connecting USB Type-C® peripherals for Data Transfer and charging the connected Host |
Note:
• This Hub supports Data and PD3.0 charging ONLY |
• Windows 10 or upwards, Mac 13.5.2 |
• 1X CSV-1548 USB Type-C® 4-port 10G Data hub with PD3.0 Charging |
Available Interfaces |
• 1x USB Type-C® Male |
• 4x USB Type-C® Female |
• Box size: 6 x 18.2 x 3.5 cm / 7.16 x 2.36 x 1.38" |
• Device size: 9.5 x 3.8 x 1 cm / 3.74 x 1.5" |
• Input Cable length approx.: 18 cm / 7" |
• Connector dimensions: 2.9 x 1.2 x 0.5 cm / 1.14 x 0.47 x 0.2" |
• Device Weight: 66 gr / 2.33 oz |
• Box Weight: 22 gr / 0.78 oz |
• Bio Degradable Bag size: 9 x 30 cm / 3.54 x 11.81" |
• Bio Degradable Bag Weight: 1 gr./ 0.04 oz |
• Total Weight: 89 gr / 3.14 oz |
- Club 3D uses environmentally friendly packaging and is printed on recycled paper. |
- Club 3D uses Bio-Degradable bags according to the EN/DIN 13432 |
Please use one of our Extension/Adapter cables to connect to your devices: In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
- CSV-1548_SPECIFICATION-SHEET_EN.pdf
- CSV-1548_SPECIFICATION-SHEET_DE.pdf
- CSV-1548_SPECIFICATION-SHEET_ES.pdf
