USB 80Gbps Certified 240W 8K240Hz Type-C® 1.2m / 3.94ft Black Cable
• EXCEPTIONAL CABLE LENGTH: 1.2m / 3.94ft
• HIGH PERFORMANCE: The NEW USB standard, USB 80Gbps supports 4K540Hz video, 240 Watt(48V/5A) EPR
• FULL COMPATIBILITY: USB 80Gbps USB-IF Certified, for guaranteed performance and compatibility with the former USB4 v2 devices, ensuring reliable signal consistency and smooth video playback on any USB Type-C® equipped display
• QUALITY CONSTRUCTION: Nickel-plated connections rated beyond 10,000 insertions; Shielded coaxial wire for enhanced EMI protection; Durable TPE Jacket and strain reliefs are halogen-free and RoHS compliant
• APPLICATIONS: Ideal for high resolution 16K/8K displays; 540Hz refresh rate at 4K resolution; Suitable for high performance GPUs and AV workstations; Supports multi-monitor daisy chains; Connect a USB Type-C® monitor to a docking station; connecting High Speed SSD's, etc.
• SPECS: 1.2m / 3.94ft Black Cable; USB-Certified 80Gbps; video 4K540Hz; charging with Power Delivery(PD) up to 240 Watt(48v/5A); E-Marker chips for protecting your devices while PD charging; 30AWG Coaxial Wire; 4.6mm (0.18inch) O.D.
USB 80Gbps Certified 240W 8K240Hz Type-C® 1.2m / 3.94ft White Cable
USB Type-C Cable to DP 2.1 Bi-Directional VESA DP80 Certified Cable M/M 1m/3.28ft
DisplayPort™ 2.1 Bi-Directional VESA DP80 Certified Cable 4K240Hz, 8K60Hz or 10K60Hz M/M 1.6m/5.25ft
Product Name: USB 80Gbps Certified 240W 8K240Hz Type-C® 1.2m / 3.94ft Black Cable
Product Series: Cable
Product Code: CAC-1570
EAN-Code: 8719214473266
UPC-Code: 841615103515
• USB 80Gbps Certified (former USB4 v2)
• Video 8K240Hz
• Cable Length 1.2m / 3.94ft max achievable in 2024 !
• USB Power Delivery 240W(48V/5A) EPR(Extended Power Range)Charging through a single cable
• Fully Bidirectional
• E-Marker chips for protecting your devices while PD charging
• Data speed up to 80Gbps
• Reversible USB Type-C® connector Male
• USB-IF TID Number 12174
Supported resolutions:
• 4K540Hz, 8K240Hz and 16K60Hz
• Windows 10 upwards, macOS 15
Available Interfaces:
• USB4 Type-C® Male
• USB4 Type-C® Male
• 1x CAC-1570 USB 80Gbps Certified 240W 8K240Hz Type-C® 1.2m / 3.94ft Black Cable
• Box size: 14.5 x 14.5 x 4.5cm / 5.71 x 5.71 x 1.77inch
• Cable length approx.: 1.2m / 3.94ft
• USB4 Type-C connector dimensions: 3.62 x 1.2 x 0.63cm / 1.43 x 0.47 x 0.25inch
• Cable Weight: 63gr / 2.2 oz
• Box Weight: 45gr / 1.59 oz
• Bio Degradable Bag size: 13 x 21cm / 5.12 x 8.27inch
• Bio Degradable Bag Weight: 2gr./ 0.07oz
• Total Weight: 110gr / 3.88 oz
Note:
Please update your TV Firmware to the version which supports these resolutions/refresh rates
Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates
Warning Safe Usage - Product Only to be used at altitude 2000 meters/6562 feet and below.
Club 3D uses Bio-Degradable bags according to the EN/DIN 13432.
