USB 3.0 to HDMI Graphics Adapter
CSV-2300H The SenseVision USB 3.0 to HDMI™ Graphics Adapter is the easiest way to add an HDMI™ Monitor, TV or Projector to an existing Desktop or Laptop via a single USB 3.0 Port.
It works as a USB Powered external Video Card with a compact design and is an ideal solution for anyone who wants to boost their productivity by expanding their desktop space. Once the driver has been installed, the USB attached monitor can be used immediately without rebooting your system. Up to 6 USB displays are supported simultaneously under Windows.
While the USB 3.0 to HDMI™ Graphics Adapter is designed for USB 3.0, it’s backwards compatible with USB 2.0, however this can influence functionality.
USB 3.0 to DVI Graphics Adapter
Product Name: Club 3D USB 3.0 to HDMI™ Graphics Adapter
Product Series: SenseVision
Item Code: CSV-2300H
EAN Code: 8717249401049
UPC code: 854365005879
• Add an HDMI™ Monitor, TV or Projector through a single USB 3.0 port
• Supports resolutions up to 2048x1152p @ 60Hz
• Supports Video streaming up to 1920x1080 Full HD
• Supports Extend and Mirror display mode
• Supports up to 6 Displays under Windows
• DisplayLink DL-3500 chip inside
• USB Powered and Portable
USB 3.0
Voltage
340mA approx
HDMI™ Female
Club 3D USB 3.0 to HDMI™ adapter
CD driver
USB Cable
GPU: AMD, Intel or Nvidia
RAM: 1GB or higher
USB port: 2.0/3.0
30MB of available disk space
Supported Operating Systems:
