USB Type-A Gen2(10G) cable, 3A M/M 0.5m / 1.64 ft
The Club 3D CAC-1409 USB Type-A Gen2(10G) cable, 3A M/M is an USB Type-A cable with a length of 0.5m / 1.64 ft. It is compatible with USB 3.1 Gen 2 with a maximum of 10Gbps data transmission and supports up to 15Watt of downstream charging. Its downward compatible with lower versions, please note that specifications will be limited to the device connected.
USB 3.2 Gen2 Type A Extension Cable 10Gbps M/F 5m/16.40ft
HDMI KVM SWITCH FOR DUAL HDMI 4K 60Hz
DisplayPort/HDMI KVM Switch For Dual DisplayPort 4K 60Hz
Product Series: Cables
Product Code: CAC-1409
EAN code: 8719214472863
UPC code: 841615103126
• Compatible with USB 3.1 Gen2 with a maximum of 10Gbps data transmission, downward compatible with lower versions (USB3.0/USB2.0)
• Support a maximum of 0.5 meters or 1.64 feet distance
• Supports a maximum of 3A downstream charging
Applications:
• Fast Data transfer up to 10Gbps via USB Type-A
• Max. 15Watt power charging(5V/3A)
• Please be aware that USB Type-A M/M connection ONLY works in a Master/Slave configuration(like HDD, Mouse, etc.) Never try to connect 2 Masters !
NOTE: To achieve a maximum of 10Gbps bandwidth, both the USB Host and the USB Device must support 10Gbps of data transmission
• Windows 10 or upwards, Mac 13.5.2
• 1X CAC-1409 USB Type-A Gen2(10G) cable, 3A M/M 0.5m / 1.64 ft
• USB Gen2 Type-A Male
• Box size: 10 x 10 x 3.5 cm / 3.94 x 3.94 x 1.38"
• Cable length approx.: 0.5m / 1.64 ft
• Connector dimensions:
  - 2x USB Type-A Male
  - 3.6 x 1.6 x 0.8 cm / 1.42 x 0.63 x 0.32"
• USB Cable Weight: 29 gr / 1.02 oz
• Box Weight: 22 gr / 0.78 oz
• Bio Degradable Bag size: 16 x 24 cm / 6.3 x 9.45"
• Bio Degradable Bag Weight: 2 gr / 0.07 oz
• Total Weight: 53 gr / 1.87 oz
