USB Gen 2 Type C 4K60Hz Active Optical Cable A/V Unidirectional M/M 20 m/ 65.62 ft
The Club 3D USB Gen 2 Type C 4K60Hz AOC cable enables the connection of your Notebook, Tablet or Phone with USB Type C output to the latest test USB C Displays. It offers Video and Data over a single 20 m/ 65.62 ft cable.
This feature ensures optimum performance between the connected devices. Supports up to 4K 60Hz UHD video. Video requires host device to support DisplayPort™ Alt Mode.
Product Name: |
USB Gen 2 Type C 4K60Hz Active Optical Cable A/V Unidirectional M/M 20 m/65.62 ft |
Product Series: Cables |
Product Code: CAC-1589 |
EAN code: 8719214471613 |
UPC code: 841615101801 |
• USB 3.2 Gen 2 4K60Hz Video and Audio through a single Cable |
• Supports resolutions up to 3840x2160@ 60Hz and 3D video |
• Reversible USB Type C connector |
• Works with Windows, Apple OS |
* Note that features are subject to the specification of the computer and GPU |
• All |
• USB Gen2 Type C to Type C Cable 20 m/65.62 ft |
Available Interfaces |
• USB Type C Male |
• USB Type C Male |
• Boxsize: 21x21x7.5 cm / 8.27 x 8.27 x 2.96 inch |
• Cable Length: 20 m/ 65.62 ft |
• Connector dimensions USB Type C: 5 x 1.3 x 0.7 cm / 1.97 x 0.51 x 0.28 inch |
• Product weight: 623 gr / 21.98 oz |
• Box Weight: 112 gr / 3.95 oz |
• Total Weight: 735 gr / 25.93 oz |
* Please update your TV Firmware to the version which supports these resolutions/refresh rates ! ** Please update your Graphic drivers on your PC and make sure that DSC1.2 is supported on your devices to support the these resolutions/refresh rates! Please use one of our Extension/Adapter cables to connect to your devices: In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you. |
- CAC-1589_SPECIFICATION-SHEET_EN.pdf
- CAC-1589_SPECIFICATION-SHEET_DE.pdf
- CAC-1589_SPECIFICATION-SHEET_ES.pdf
