![](banner/600x600/2_1.jpg)
USB Tipo-C a VGA + USB 3.0 + USB Tipe-C Cargar Mini Dock
CSV-1532 El Hub SenseVision USB Tipo-C a VGA + USB 3.0 + USB Tipe-C Cargar Mini Dock es muy portable y útil para el uso de su portátil con puerto USB Tipo-C o Ultrabook que ofrezca DisplayPort™ en modo Alternativo.
Añada un monitor VGA con resoluciones de hasta WQXGA 2560x1600p a través de la salida D-Sub y conecte el puerto USB3.0 Tipo-A a sus memorias USB, periféricos y discos duros externos. Use el puerto USB Tipo-C con entrega de potencia para cargar su dispositivo conjuntamente. Soporta Microsoft Windows y Apple OS X, require DisplayPort™ Alt Mode.
Model |
Product Name: USB 3.1 Typ -C to VGA and USB Mini Docking Station |
Product Series: SenseVision |
Weight: 51 gr |
Connector length: 55mm |
Item Code: CSV-1532 |
EAN Code: 8719214470487 |
UPC Code: 841615100613 |
Interface |
USB 3.0 Type-C male x 1 |
Output Configuration |
D-Sub VGA female x 1 |
USB 3.0 Type-A female x1 (for Data) |
USB 3.0 Type-C female x1 (for Charging) |
In the package |
SenseVision USB 3.0 Type C to VGA and USB Mini Docking Station |
Quick install guide |
• Innovative Portable Design |
• Folding USB Type C Connector |
• Supports analog VGA monitor |
• Supports up to 270MHz video pixel clock |
• Supports up to WQXGA resolution (2560x1600p) |
• 1x USB 3.0 (3.1 Gen1) Type-A port for Data (max 5Gbps) |
• 1x USB Type C PD port (5V/ 1.5A, 20V/3A) |
• Requires Type C DisplayPort™ Alt Mode |
The minimum requirements for the PC are: |
CPU: AMD or Intel Dual Core CPU 2GHz or higher processor clock. |
GPU: AMD, Intel or Nvidia |
RAM: 1GB or higher |
USB port: Type C must support DisplayPort™ Alt Mode |
30MB of available disk space |
Supported Operating Systems: |
Windows 7 (32 & 64 Bit) |
Windows 8.1 (32 & 64 Bit) |
Windows 10 (32 & 64 Bit) |
Apple OS X |
