![](banner/600x600/13_1.jpg)
DisplayPort™ 1.4 HBR3 Cable VESA Certified M/M 2 m / 6.56ft 28AWG
The Club 3D CAC-2068 DisplayPort™ 1.4 HBR3 VESA Certified Cable enables the connection of your DisplayPort™ supported (Gaming) PC or Laptop to an (Ultra) High Resolution Monitor or other DisplayPort™ supported device to Support resolutions up to 8K60Hz. DisplayPort™ 1.4 adds support for Display Stream Compression 1.2 (DSC), Forward Error Correction, and extends the maximum number of inline audio channels to 32. It features locking DisplayPort™ connectors providing a secure, dependable connection. Simply press the built-in one-touch latch button to unlock the connector. The soft UltraFlex jacket protects the cable from bends and deformation damage.
Product Name: |
DisplayPort™ 1.4 HBR3 Cable VESA Certified M/M 2 m / 6.56ft 28AWG |
Product Series: Cables |
Product Code: CAC-2068 |
EAN code: 8719214470821 |
UPC code: 841615101016 |
• Fully DisplayPort™ Version 1.4 Compliant, HBR3, 32.4Gbps |
• VESA Certified |
• Downwards compatible to older Displayport standards |
• Support resolutions up to 8K60Hz |
• All |
• CAC-2068 DisplayPort™ 1.4 HBR3 Cable VESA Certified M/M 2 m / 6.56ft 28AWG |
Available Interfaces |
• DisplayPort™ 1.4 Male |
• Packaging size: 21.5 X 15 x 3.2 cm/ 8.46 x 5.9 x 1.26" |
• Poly Bag Weight: 7 gr / 0.25 oz |
• Product Weight: 132 gr / 4.66 oz |
• Product height: 1.2 cm / 0.47" |
• Product width: 1.9 cm / 0.35" |
• Product Length: 2 m / 6.56 ft |
- CAC-2068_SPECIFICATION-SHEET_EN-2023.pdf
- CAC-2068_SPECIFICATION-SHEET_DE-2023.pdf
- CAC-2068_SPECIFICATION-SHEET_ES-2023.pdf
