Ultra High Speed HDMI 4K120Hz, 8K60Hz Certified Cable 48Gbps M/M 2 m / 6.56 ft
The Club 3D CAC-1372 Ultra High Speed HDMI™2.1 Certified Cable is built to handle the highest quality video- and audio- signals.
Enhanced refresh rate features:.
- HDMI™2.1 also supports Static- and Dynamic HDR metadata.
All HDMI™2.1 features are fully supported by this Club 3D CAC-1372 Cable. It is the ideal solution for the ultimate future proof HDMI™2.1 experience.
Product Name:. |
Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Cable 48Gbps M/M 2 m/6.56 ft |
Product Series: Cable |
Product Code: CAC-1372 |
EAN code: 8719214471156 |
UPC code: 841615101344 |
Features:. |
• Fully Compliant to the Ultra High Speed HDMI™2.1 Certified specification |
• Professional quality cable |
• Low EMI emission |
• Gold plated connectors for maximum conductivity and 28 AWG |
• Enhanced gaming and media features |
• Color space BT.2020 with 10bits,12bits,16bits |
• Backwards compatible to earlier HDMI™ versions |
• Supports (U)HD resolutions up to 4K120Hz (with DSC 1.2) or 8K60Hz |
• Supports Enhanced Audio Return Channel (eARC) |
• Supports Static- and Dynamic- HDR Metadata |
• Support for VRR, QMS, QFT and Auto Low Latency Mode |
• All |
• 1x Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Certified Cable 48Gbps M/M |
Available Interfaces |
• HDMI™ Male |
• HDMI™ Male |
• Box size: 14.5 x 14.5 x 4.5 cm / 5.71 x 5.71 x 1.77 inch |
• Cable length approx.: 2m /6.56ft |
• Connector dimensions: 5 x 2 x 1 cm / 1.97 x 0.79 x 0.39 inch |
• Cable Weight: 118gr / 4.16 oz |
• Box Weight: 46 gr / 1.62 oz |
• LDPE Bag Weight: 9 gr / 0.32 oz |
• Total Weight: 173 gr / 6.10 oz |
Note: |
This Club 3D HDMI™ * cable is also suitable for: Xbox Series X, Xbox Series S, PlayStation 5, Nvidia RTX 3000 series, AMD Radeon RX 6800 series. |
* Please check your TV/monitor user-manual for its required specifications and maximum resolutions. |
- CAC-1372_SPECIFICATION-SHEET_EN.pdf
- CAC-1372_SPECIFICATION-SHEET_DE.pdf
- CAC-1372_SPECIFICATION-SHEET_ES.pdf
