The Club 3D CAC-1372 Ultra High Speed HDMI™2.1 Certified Cable is built to handle the highest quality video- and audio- signals.
Enhanced refresh rate features:.
- HDMI™2.1 also supports Static- and Dynamic HDR metadata.
All HDMI™2.1 features are fully supported by this Club 3D CAC-1372 Cable. It is the ideal solution for the ultimate future proof HDMI™2.1 experience.
Premium High Speed HDMI™ 4K60Hz UHD Cable M/M 1 m / 3.28 ft 30AWG
Product Name:.
Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Cable 48Gbps M/M 2 m/6.56 ft
Product Series: Cable
Product Code: CAC-1372
EAN code: 8719214471156
UPC code: 841615101344
Features:.
• Fully Compliant to the Ultra High Speed HDMI™2.1 Certified specification
• Professional quality cable
• Low EMI emission
• Gold plated connectors for maximum conductivity and 28 AWG
• Enhanced gaming and media features
• Color space BT.2020 with 10bits,12bits,16bits
• Supports (U)HD resolutions up to 4K120Hz (with DSC 1.2) or 8K60Hz
• Supports Static- and Dynamic- HDR Metadata
• All
• 1x Ultra High Speed HDMI™ 4K120Hz, 8K60Hz Certified Cable 48Gbps M/M
• HDMI™ Male
• HDMI™ Male
• Box size: 14.5 x 14.5 x 4.5 cm / 5.71 x 5.71 x 1.77 inch
• Cable length approx.: 2m /6.56ft
• Connector dimensions: 5 x 2 x 1 cm / 1.97 x 0.79 x 0.39 inch
• Cable Weight: 118gr / 4.16 oz
• Box Weight: 46 gr / 1.62 oz
• LDPE Bag Weight: 9 gr / 0.32 oz
• Total Weight: 173 gr / 6.10 oz
Note:
POSSIBLE RESOLUTIONS
