HDMI 2.0 UHD Active Optical Cable HDR 4K 60Hz M/M 50m/164,04ft
CAC-1391 - The Club 3D HDMI™ 2.0 Hybrid Active Optical Cable features both fiber and copper conductors, providing a lighter, more flexible cable construction, which makes it ideal for installation in narrow spaces and over longer distances. The perfect solution for conference rooms, classrooms, digital signage displays, and more.
This CAC-1391 features a built-in booster circuit that is self-powered through the HDMI ports, allowing you to connect your HDMI-enabled devices at a distance of up to 50 meters with no signal loss.
The cable is Halogen Free, and produced according to the International Electrochemical Commission's Restriction Use of Halogen (IEC 61249-2-21) directive.
This cable features unidirectional architecture, which requires that the cable is installed in the correct direction. Please refer to the source and display labels on the HDMI connectors, in order to ensure that the cable is connected properly.
Model: |
Product Name: HDMI™ 2.0 Hybrid Active Optical Cable HDR 4K 60Hz M/M 50m/ 164,04ft |
Product Series: Cables |
Itemcode: CAC-1391 |
EAN code: 8719214471088 |
UPC code: 841615101276 |
• Compliant to HDMI™ specification version 2.0b (600Mhz Clock Frequency) |
• Gold plated connectors for maximum conductivity |
• Supports UHD TV resolutions up to 4096x2160p @ 60Hz |
• Supports 3D resolutions up to 1080p Full HD @ 120Hz |
• Total Data bandwidth of 18Gbps |
• Supports Dolby® True HD, DTS-HD Master Audio up to 32 audio channels |
• Halogen Free and without EMI/RFI emission |
• Support for HDR/HDCP/EDID/CEC/DDC |
• Plug and Play, no driver software required |
• Unidirectional - meaning Source and Display only |
• This cable is Hybrid which makes it downwards compatible to other HDMI versions |
All |
HDMI™ 2.0 Male |
HDMI™ 2.0 Male |
• Box size: 230 x 230 x 100 mm. |
• Box Weight: 162 gr. |
• Product Weight: 1348 gr. |
• Cable + Bag : 1357 gr. |
• Product + Box + Bag Weight: 1519 gr. |
• Product height: 90 mm. |
• Product width: 170 mm. |
• Product Length: 50 meter/ 164,04 feet |
• Made in China |
• HDMI™ 2.0 Hybrid Active Optical Cable HDR 4K 60Hz M/M 50m/164,04ft |
This Club 3D HDMI™ * cable is also suitable for: Xbox One, Xbox One S, Xbox 360, PlayStation 4, PS3, Nintendo Switch |
* Please check your TV/monitor user-manual for its required specifications and maximum resolutions. |
- SPECIFICATION-SHEET-CAC-1391_EN.pdf
- SPECIFICATION-SHEET-CAC-1391_DE.pdf
- CLUB-3D-NEWSL-CAC-1390+1391-EN-1.pdf
