MiniDisplayPort 1.2a to Dual Link DVI-D Active Adapter
CAC-1130 - The Mini DisplayPort™ + USB Type A (for Power) to Dual Link DVI signal format converter seamlessly connect Mini DisplayPort™ based source to conventional DVI displays, such as CRT, LCD monitors and projectors, you can enjoy the ultimate widescreen canvas with a resolution of 2560 x 1440 @ 60Hz and up to 3840 x 2160 @ 30Hz on any other capable display.
Mini DisplayPort 1.2 HBR2 Cable M/M 2m/6.56ft
Mini DisplayPort 1.2 Cable to HDMI UHD 4K60Hz Active Adapter M/M 3m/9.84Ft
Product Name: Mini DisplayPort™ to Dual Link DVI Active Adapter
Product Series: Adapter
Itemcode: CAC-1130
EAN code: 8719214471385
UPC code: 841615101566
• Support Mini DisplayPort™ 1.2a input and Dual Link DVI or Single-Link DVI output.
• Support Dual-Link DVI highest video resolution to WQXGA 2560 x 1600 @ 60Hz * For Apple users see Checklist under Download
• Support Dual-Link DVI highest video resolution 3840*2160 @ 30Hz
• Support Single-Link DVI highest video resolution 1920 x 1080
• Support deep color 24bit
• Powered from DisplayPort™ source and USB Type A Port.
All
• Club 3D Mini DisplayPort™ to Dual Link DVI Active Adapter
• Mini DisplayPort™ Male
• USB Type A power Male
• DL DVI Female
• Box size: 14,5 x 14,5 x 4,5 cm
• Box size: 5,51 x 5,51 x 1,57 inch
• Adapter size: 1,4 x 6,1 x 8,3 cm
• Adapter size: 0,39 x 2,36 x 3,15 inch
• Cable length: approx. 60 cm / 23,62 inch
• Device Weight: 109 gr. / 3.84 oz.
• Box Weight: 64 gr./ 2.26oz.
• Total Weight: 173 gr. 6.1 oz.
