DVI-D Dual Link (24+1) Cable Bidirectional M/M 10m/32.8ft 28AWG
The Club 3D CAC-1220 is a DVI-D(24+1) Male to DVI-D(24+1) Male Cable. This cable is fully Bidirectional.
This CAC-1220 Cable is the easiest solution for connecting your DVI-D Monitor, Projector or Television to the DVI-D output of your PC / Note- book / Game Console.
The CAC-1220 uses premium components and gold plated contacts to ensure the highest performance and maximum ease of use resulting in the best user experience with resolutions up to 2560 × 1600 (WQXGA)@ 60 Hz or 1920 x 1080 @ 120Hz, provided your graphic card and your monitor supports these resolutions.
Please use one of our DVI-D (Extension/Adapter) cables to connect to your devices: In case you need assistance to choose the correct cable, please visit our website www.club-3d.com or feel free to mail us at [email protected] and it will be our pleasure to assist you.
Product Name: CAC-1220– DVI-D Dual Link (24+1) Cable Bidirectional M/M 10m/32.8ft 28AWG |
Product Series: Cables |
Itemcode: CAC-1220 |
EAN code: 8719214471491 |
UPC code: 841615101689 |
• Compliant to DVI-D Dual Link specification |
• Supports resolutions up to 2560 × 1600 (WQXGA)@ 60 Hz or 1920 x 1080 @ 120Hz |
• Fully Bidirectional |
• No external power needed |
• Plug & Play |
OS Support: All |
In the box: CAC-1220 Cable |
Input: DVI-D (Male) |
Output: DVI-D (Male) |
• Box size: 21 x 21 x 6.5 cm |
• Box size: 8.3 x 8.3 x 2.6 inch |
• Cable Length : 10 m / 32.81 ft |
• Connector dimensions : 5.3 x 4 x 1.5 cm |
• Connector dimensions : 2.1 x 1.6 x 0.6 inch |
• Cable Weight: 850 gr / 30 oz |
• Box Weight: 98 gr / 3.5 oz |
• Total Weight: 858 gr / 33.5 oz |
