Premium High Speed HDMI™ 4K60Hz UHD Cable M/M 1 m / 3.28 ft 30AWG
CAC-1311 - Premium High Speed HDMI™ 4K60Hz UHD Cable M/M 1 m / 3.28 ft 30AWG
The Club 3D Premium High Speed HDMI™ 4K60Hz UHD Cable enables the connection of your HDMI™ 2.0 supported Gaming PC or Laptop to an (Ultra) High Definition Monitor or other HDMI™ 2.0 supported device. It fully supports the ‘Premium High Speed HDMI™ with Ethernet’ specification, ensuring that video up to 4K UHD 3840x2160p at 60Hz is supported, as well as HDR, audio and data streams. The cable combines the unmatched signal quality and convenience of HDMI™ connectivity with the power and flexibility of home entertainment networking. It includes a dedicated data channel into the HDMI™ link, enabling high speed networking at up to 100 Mbps. It is the ideal solution for the ultimate future proof HDMI™ 4K UHD Gaming and Viewing experience.
Product Name:Premium High Speed HDMI™ 4K60Hz UHD Cable M/M 1 m / 3.28 ft 30AWG
Product Series: Cable
Item Code: CAC-1311
EAN Code: 8719214470708
UPC Code: 841615100873
• Compliant to Premium High Speed HDMI™ with Ethernet specification
• Professional quality cable 30 AWG
• Supports HDMI™ 2.0 specification
• Backwards compatible to support HDMI™ 1.4 specification
• Fully Bi-Directional
• Supports (U)HDTV resolutions up to 3840x2160 @ 60Hz and HDR
• Supports 3D resolutions up to 1920x1080p Full HD @ 120Hz• Total Data throughput of 18Gbps, three lanes, 6Gbps per lane
All
Connector 1:
HDMI™ Male
Connector 2:
HDMI™ Male
Other Info:
• Boxsize: 14.5 x 14.5 x 4.5 cm
• Box size: 5.7 x 5.7 x 1.8 inch
• Cable Length : 1 m / 3.28 ft
• Connector dimensions: 5.8 x 2 x 1 cm / 2.3 x 0.8 x 0.4 inch
• Device Weight: 104 gr / 3.7 oz
• LDPE Bag Weight: 5 gr/ 0.2 oz
• Box Weight: 45 gr / 1.6 oz
• Total Weight: 154 gr / 5.5 oz
In the Box:
Club 3D Premium High Speed HDMI™ 4K60Hz UHD Cable 1m/3.28ft
POSSIBLE RESOLUTIONS
