Mini DisplayPort to DisplayPort™ Adapter
CAC-1110 The Club 3D is a Mini DisplayPort to DisplayPort™ converter. It accepts a Mini DisplayPort™ input from a Mini DisplayPort™ enabled Desktop or Laptop and converts to a full size DisplayPort™ output allowing the use of DisplayPort™ enabled Televisions, Monitors or Projectors. The adapter offers hassle free plug and play functionality.
The Mini DisplayPort to DisplayPort™ adapter is compliant to the DisplayPort 1.2a specification and supports (Ultra) High Definition resolutions up to 3840x2160p and AMD FreeSync™. Supports DisplayPort™ 1.4 provided the source supports it.This professional grade adapter-cable is ceritfied by Vesa.
Supports resolutions up to 4K60Hz 3840x2160p @ 60Hz.
The adapter works with AMD, Nvidia and Intel Graphic Solutions and supports AMD FreeSync™.
Mini DisplayPort to DisplayPort 1.2 M/M 2m/6.56ft
Product Name: Mini DisplayPort to DisplayPort™ Adapter
Product Series: Accessories
Weight: 40 gr
Cable length: 130 mm
Item Code: CAC-1110
EAN Code: 8717249408512
UPC Code: 854365005152
• Mini DisplayPort 1.2a compliant adapter
• Connects Mini DisplayPort sources to DisplayPort™ (display) devices
• Supports DisplayPort™ 1.4 provided the source supports it.
• display resolutions up to 4K 3840x2160p at 60Hz
• Supports HDTV formats up to 3840x2160p 4K Ultra HD
• Powered by the Mini DisplayPort output
• Vesa ceritfied
Connector 1:
Mini DisplayPort™ Male
Connector 2:
DisplayPort™ Female
Operating Systems
Windows, Apple OS X
In the Box
Club3D CAC-1110 Mini DisplayPort™ to DisplayPort™ Adapter
