DisplayPort to HDMI Passive Adapter
CAC-1001 The Club 3D is a passive HDMI™ signal converter. The DisplayPort™ to HDMI™ Adapter is the easiest solution for connecting your DisplayPort™ enabled source device to an HDMI™ enabled High Definition Television, monitor or Projector.
The adapter works with AMD, Intel and Nvidia graphics solutions and supports a maximum resolution of 1920x1200p. Simply connect the DisplayPort™ (male) end of the connector to your computer and plug your existing HDMI™ cable from the display into the HDMI™ (female) adapter. Setup requires no software installation. The circuitry built into the adapter seamlessly converts the DisplayPort™ video signal into a HDMI™ video signal.
Supports resolutions up to 1920 x 1200p @ 60Hz
This professional grade adapter-cable is ceritfied by Vesa
DisplayPort™ 1.4 to HDMI™ 2.0b HDR Active Adapter
Product Name: DisplayPort™ to HDMI™ Passive Adapter
Product Series: Adapter
Weight: 56 gr
Cable length: 180 mm
Item Code: CAC-1001
EAN Code: 8717249408444
UPC Code: 854365005077
• Club 3D DisplayPort™ to HDMI™ Passive Adapter
• Compliant to DisplayPort™ 1.1a Specification
• Compliant to HDMI™ 1.3 specification
• Supports resolutions up to WUXGA 1920x1200p
• No external power needed
• Supports AMD, Nvidia® and Intel® HD/ Iris™ graphics solutions
• Vesa Certified
Connector 1:
DisplayPort™ Male
Connector 2:
HDMI™ Female
Operating Systems
Windows, Apple OS X
In the Box
Club 3D CAC-1001 DisplayPort to HDMI™ Passive Adapter
AMD EYEFINITY
