USB Type-C (with USB Type-A adapter) to dual DisplayPort™(4K60Hz) Video Splitter
The Club 3D CSV-1478 USB Type-C (with USB-A adapter) to dual DisplayPort™ (4K60Hz) Video Splitter with DisplayLink® which provides most advanced, efficient solution. It supports max. single 4K60Hz or dual 4K60Hz simultaneous output of different videos(Extened Desktop). It can work on USB Mode and DP™ Alt mode supported USB Type-C and USB Type-A hosts.
USB3.2 Gen1 Type A to DisplayPort™1.2  Dual Monitor 4K60Hz Video Splitter
DisplayPort 1.4 HBR3 8K Cable M/M 5m /16.40ft
Product Name: USB Type-C (with USB Type-A adapter) to dual DisplayPort™(4K60Hz) Video Splitter
Product Code: CSV-1478
EAN code: 8719214472993
UPC code: 841615103256
• Support DisplayLink®
• Support DisplayPort™max. 4K60Hz per port
• Support to output dual 4K60Hz simultaneously with different pictures(Extended Desktop) on both USB Type-C and USB Type-A hosts
• Support outputting different pictures on both Windows and Apple including M1 and M2 silicon
• Windows 10 or upwards, Mac OS 14.2.1
• 1X CSV-1478 USB Type-C (with USB Type-A adapter) to dual DisplayPort™ (4K60Hz) Video Splitter
• 1x USB Type-C (with USB Type-A Adapter) Male(Connect to host)
• 2x DisplayPort™ Female
• Box size: 8 x 25 x 3.5 cm / 3.15 x 9.84 x 1.38"
• Device size: 9 x 6.1 x 1.4 cm / 3.54 x 2.4 x 0.55"
• Input Cable length approx.: 18.5 cm / 7.29"
• Connector dimensions:
-USB Type-A(Adapter): 3.1 x 1.6 x 0.9 cm / 1.22 x 0.63 x 0.35"
-USB Type-C: 2.5 x 1.2 x 0.7 cm / 0.98 x 0.47 x 0.28"
• Device Weight: 95 gr / 3.35 oz
• Box Weight: 32 gr / 1.13 oz
• Bio Degradable Bag size: 9 x 30 cm / 3.54 x 11.81"
• Bio Degradable Bag Weight: 1 gr./ 0.04 oz
• Total Weight: 128 gr / 4.52 oz
- Club 3D uses environmentally friendly packaging and is printed on recycled paper.
- Club 3D uses Bio-Degradable bags according to the EN/DIN 13432
Warning Safe Usage - Product Only to be used at altitude 2000 meters/6562 feet and below
